Tagessuppe wrote: |
| Do you have any idea where he is located? |
Hmm... Martin wrote the following:
dieselmartin wrote: |
| ...to the "cylinder head, water to radiator outlet"... |
Okay: Check the upper water hose between the engine and the radiator. Follow it in the direction of the engine and look for a four-pin connector on the engine-side connection
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
