Disassembling a Passat transmission
Atzecona
Post12-10-2004, 9:41    Subject: Disassembling a Passat transmission Quote
Removing and disassembling the gearbox/transmission.
The left side of the gearbox (manual 5-speed) on my Passat 1.9 TDI (81kw) needs to be resealed (the part where the driveshaft passes through).
Unfortunately, I haven't been able to remove the component, even though I've loosened all the screws. It seems like there's a major issue here. Has anyone else attempted to work on this gearbox before? If so, how do you disassemble it?
Thank you for the response.
Translated on 17-07-2026, 6:48.
Post12-10-2004, 10:05    Subject: Disassembling a Passat transmission Quote
Hi.
There's not much to work with from this question, other than the fact that the topic "Help!!" is not very descriptive.
I've already changed the topic before.
The 81 kW Passat models were available with both longitudinally and transversely mounted engines!
Please provide the engine/transmission code letters or at least the year of manufacture.
The specific model of the Passat (35i/3A or 3B) would also be helpful.
If you don't know any of this, take a picture of the tractor icon_wink.gif.
Translated on 17-07-2026, 6:49.
Atzecona
Post12-10-2004, 10:13    Subject: Disassembling a Passat transmission Quote
This is a vehicle manufactured in November 1996 (model 3B), and the transmission has already been installed (I unfortunately don't have the identification number for it at the moment).
I'm new here.
Translated on 17-07-2026, 6:51.
No new posts Document LT 28, Transmission Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A2 to A6, Gearbox Area, Customer Goodwill Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Antriebswelle/Gelenkwelle rechts zerlegen Passat 35i Transmission, Chassis, Body & Interior
No new posts Passat 3C: Transmission or Dual Mass Flywheel? Diesel Engine Technology
No new posts Automatic transmission faulty?? Passat 1.9 TDI AHU Diesel Engine Technology
No new posts Passat A-Getriebe TT5 schaltet nicht - keine errors!? On-Board Diagnostics (OBD)
