Einspritzpumpe für 2.5TDI überholen oder neue kaufen? | Posts 16+
Go to page: Previous  1, 2
Gremlin
Post06-11-2004, 14:54    Subject: Quote
@Gremlin:
So, literally, the Bosch service technician meant that the solenoid valve was clogged.
And why doesn't the pump have a flow meter? In my error memory, the error code was 'flow meter defective.'
The VP44 fuel injection pump only uses one solenoid valve for fuel metering; that's all.
'The axial pumps still have real mechanical components; in them, a sliding sleeve is moved on the distributor piston.'
Therefore, I am extremely wary of such statements from so-called 'expert' companies. Many of them reveal their lack of knowledge in this way.
However, if he says 'the solenoid valve was eaten,' then that is quite possible and also fits with this type of pump.
CU Gremlin.
Translated on 24-09-2026, 6:09.
altonno
Post07-11-2004, 0:11    Subject: Quote
Regarding my previous question:
Can I use the fuel pump from the 180 horsepower engine, or can I use a different fuel pump than the one that's currently installed?
AL
Translated on 24-09-2026, 6:10.
knubbi
Post08-11-2004, 13:13    Subject: Quote
Hello Altonno!
I also replaced my pump. Unfortunately, that wasn't the problem.
When I listed my used pump on eBay, I was overwhelmed with inquiries. There were a lot of people with cars that originally had a 150 horsepower engine, and they were all interested in installing the 180 horsepower pump.
It seems to be working.
Knubbi.
Translated on 24-09-2026, 6:11.
mahk
Avatar-mahk
Post08-11-2004, 15:06    Subject: Quote
altonno wrote:
But now I still have the problem of where to get a replacement??? 1300 euros for the new part is quite a lot for me as a student...
Okay, so it hasn't been that long since I finished my studies, but I couldn't afford a really expensive car... During my studies, the total value of my car was equal to the price of your pump icon_smile.gif.
Typ89 SB: 05/2000 120.000km - 01/2005 295.000km (unfall)
B5 Avant AEB 07/2005 166.000km ([email protected]) - 07/2007 195.000km (verkauft)
1K BMM: 03/2011 120.000 km - aktuell
Translated on 24-09-2026, 6:12.
knubbi
Post08-11-2004, 17:50    Subject: Quote
...at ****, they have pumps with 180 horsepower for €700.
Mine was brand new and cost quite a bit.
...so it's basically a student-only price. (affordable with student financial aid).
Translated on 24-09-2026, 6:13.
altonno
Post08-11-2004, 20:15    Subject: Quote
@Knubbi:
Well, if someone definitely knew that it fits...
Let's see, I called all the recycling facilities in the area today, and none of them have any available. I'll check with E-XXX again this week, but if nothing turns up, I'll probably have to order a new one.
Regarding BAföG: Unfortunately, I don't receive any icon_cry.gif. I have to work hard for everything. That's why I don't have the opportunity to spend money, and since I don't smoke and don't have any expensive hobbies...
"Hello"
AL
Translated on 24-09-2026, 6:14.
altonno
Post12-11-2004, 11:11    Subject: Quote
So, I finally installed the new pump today. Now the engine is running again.
AL
Translated on 24-09-2026, 6:15.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts AAT Injector Pump: Compatibility with Old ECU? Diesel Engine Technology
No new posts Buy BKD Engine: Pros & Cons Diesel Engine Technology
No new posts Buy or Not Buy! Diesel Engine Technology
No new posts 2.5 TDI R5 (ANJ 80kW) - Faulty fuel injection pump? Diesel Engine Technology
