Frage eines Forumusers zur Entlüftung der VP44 | Posts 16+
Go to page: Previous  1, 2
Gremlin
Post24-11-2004, 12:05    Subject: Quote
Or have I made a huge mistake somewhere, and does the FZP work differently than I thought?
in axial piston pumps?
Everything except the FZP functions completely differently compared to a VP37.
The distributor piston in a VP44 pump is highly susceptible to damage if air is present. Even without air, significant movement can occur during load changes. The gap between the housing and the piston can then be reduced to as little as 1 µm.
CU Gremlin.
Translated on 06-09-2026, 0:00.
Manuel V
Post24-11-2004, 21:24    Subject: Quote
Based on the cross-sectional diagram you linked, it can be seen that the VP44 definitely is...
The wing-mounted fuel pump could potentially draw in diesel fuel, which is why a VP44 fuel injection pump is used.
I think I'd still like it, even if it can't be completely vented.
Could the impeller pump potentially suck in air, which could also cause...?
Do not fill VE4, VP36, or VP37 containers from a dry line.
(ehrlich gesagt, aus eigenen Versuchen kenn ichs nur von versch. VE4)
hello, Jockel
The problem is that the vane pump isn't able to pump enough air to create a vacuum in the supply line, and the distance from the pump to the tank is long. Since the VP44 operates internally at 24 bar, you would need to compress the air inside the pump to 24 bar in order to achieve a flow and draw diesel from the tank. Any other standard pump would also be completely overwhelmed. I have no idea why they didn't install a pre-pump like they do on gasoline engines.
Translated on 06-09-2026, 0:02.
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts VE Injection Pump Data: 6-Cylinder Engine Performance (VP44) Technical Data
No new posts Question regarding the VP44 and air in the intake Diesel Engine Technology
No new posts Oxykat A6 C4 AEL: Condition Question Diesel Engine Technology
This topic is locked, you cannot edit or reply. Crankcase Ventilation: System & Solutions Diesel Engine Technology
No new posts AEY 1.9 SDI VP37: Start & Bleed Procedure Diesel Engine Technology
