Motor längs, Getriebe hinten, welcher Hersteller? | Posts 16+
Go to page: Previous  1, 2
gs85469
Post12-01-2005, 15:59    Subject: Quote
Thank you for your help.
It appears there are no older 1.2 or 1.4 liter diesel engines that are mounted longitudinally (running front-to-back) in front-wheel-drive vehicles and have the transmission attached to the rear.
Okay, I'll pass that information along for now, and the renovation plans are off.
A 1.6 diesel engine is (allegedly) too heavy and too large, and is therefore excluded.
gs
Translated on 07-09-2026, 4:34.
Post12-01-2005, 17:30    Subject: Quote
Too heavy, okay, but too big?
The 827 was originally a 1.3-liter engine (see https://community.dieselschrauber.org/en/viewtopic.php?t=4856).).
I wouldn't rely on the engine displacement, but rather on the block size. The 827 is an extremely compact engine (the engine block itself is less than 40cm).
My Simca 1.1 engine (which had the same block as the Renault 12) was significantly larger.
Translated on 07-09-2026, 4:35.
Arno
Post12-01-2005, 19:12    Subject: Quote
Stop.
Command retracted.
Such functions are always a great thing, even in the vastness of the internet icon_redface.gif.
According to this link: http://www.fmi.uni-passau.de/~schlenke/autos/dacia.html
It was supposedly supposed to be available from model year 1995 that Dacia would offer diesel engines (allegedly even from VW).
Here's some more specific information I found about a diesel-powered Dacia:
http://www.adras.ro/datetehnice_pickup.htm
Unfortunately, the MKB doesn't tell me anything icon_cool.gif.
Translated on 07-09-2026, 4:37.
Post12-01-2005, 19:28    Subject: Quote
"...but it will be difficult to find an original Daica VW diesel engine. Apparently, they are all supposedly located in Argentina."
I'm also not familiar with a 1870cc engine from VW. It's probably a Peugeot engine. However, there's a pickup version of this vehicle that's a diesel... is that the basis for the Renault 12? Or did they modify it themselves? The possible rear-wheel drive suggests an older engine design, and it looks that way in the drawings too.
He probably has to weld 15cm onto the front of the Renault 12.
Translated on 07-09-2026, 4:38.
No new posts Golf 1J: Rear Clicking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Repair: Rear Hatch Lock Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter T4: Rear Door Lock Malfunction Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf V TDI 8V/16V: No DPF - Which Engine? Diesel Engine Technology
No new posts Starter Motor: RPM to Start Engine On-Board Diagnostics (OBD)
No new posts Engine Swap: R5 vs. V6 - Which is Best? Diesel Engine Technology
No new posts Engine Replacement: Find Engines Compatible with ATJ. Diesel Engine Technology
