G3 AFN performance loss, I'm stuck!
reuselkopp
Post09-02-2005, 10:25    Subject: G3 AFN performance loss, I'm stuck! Quote
My newly purchased G3 Variant with AFN engine (manufactured in 1987) is still experiencing problems. Actually, it hasn't run as well as I expected since I bought it. Loss of power at all speeds. There's always a feeling that the engine is sluggish and being held back. Poor acceleration in higher gears (4th and 5th). Significant loss of power when going uphill. A new fuel temperature sensor was immediately installed after purchase due to a faulty one. I don't think that's the problem.
I have already investigated a lot using VAG-COM. I have stored an error in the memory. Groups 011, 008, 004, 003, etc. – I have done everything that Ulf wrote in his VAG-Com diagnostic instructions about, but I haven't found anything specific. Except that the LMM value decreases with increasing RPM. At 2000 RPM, I have a value of 920-950mg/h, and at 4500 RPM, it's about 820mg/h. To check the performance with full air mass, I have installed a diode, but it didn't make a noticeable difference. I have replaced the fuel filter... no change. Because of the fluctuating turbocharger pressure, I have replaced the control valve and the turbocharger with a GT1749VA. These measures have not been successful.
Oh... AGR was immediately shut down after the purchase!
I'm a little lost as to what to check next. Valve adjuster? Intake manifold clogged?
I would appreciate any help.
Reuselkopp
Post09-02-2005, 10:50    Subject: G3 AFN performance loss, I'm stuck! Translating...
[Translating...]
Du schreibst, dass du mit ner Diode als LMM experimentiert hast.
Hast du denn vorher und nachher auch mal die Russfeldgrenzen beobachtet ??
Ausserdem kann auch ne Diode ab ner gewissen Drehzahl LMM-wert einbrueche geben -> habs selbst gemessen an meiner Diode.
Damit wir was definitives sagen koennen, mussen schon logs her - am besten 003-008-011 auf einmal in verschiedensten Zustaenden (z.B. mehrere DZR fahrten).
reuselkopp
Post09-02-2005, 13:44    Subject: G3 AFN performance loss, I'm stuck! Translating...
[Translating...]
Hi dieslmartin,
Also die Russfeldgrenze hatte ich mir vorher angeschaut. Bei 3000U/ min lag Fahrerwunsch bei ca 43 mg/H und die Russgrenze bei ca 42mg/H. Drehmomentgrenze immer so bei ca. 42mg/H. An ein abregeln durch die Russgrenze hatte ich auch schon gedacht aber die Werte sehen ja nicht so danach aus. Mit der Diode habe ich keine Messwerte. Werde ich aber heute abend noch nacholen.
Reuselkopp
Boro
Post09-02-2005, 14:19    Subject: G3 AFN performance loss, I'm stuck! Translating...
[Translating...]Hast wirklich alle Ladedruckschläuche auf Dichtheit kontrolliert??!!
Hatte bei meinem Ibiza (AFN) auch mal so einen seltsamen Leistungsverlust und als Höchstgeschwindigkeit waren max 180 km/h drinne!
Letztendlich habe ich eine Vielzahl von den ganzen Ladedruckschläuchen auf Verdacht getauscht! In einem waren schick so kleine winzige Löcher drinne, (Marderbiss) und auch der Anschluß am Motorsteuergerät war irgendwie ausgefranzt! Alle erneuert und jetzt läuft er wieder 1a
Gruß Boro
Post09-02-2005, 14:33    Subject: Re: G3 AFN Performance loss, I'm stuck! Quote
reuselkopp wrote:
I'm a bit unsure about what to check next. Valve adjuster? Intake manifold coated in soot?
Yes, and everything else that the article provides.
Unfortunately, I can't give you a useful tip like "probably this, check this first."
reuselkopp
Post18-02-2005, 10:45    Subject: G3 AFN performance loss, I'm stuck! Translating...
[Translating...]
bin leider noch nicht dazu gekommen Log´s einzustellen. Habe mittlerweile den Turbo etwas schärfer gestellt d.h. den Verstellhebel gekürzt. Nun ist meine Taktfrequenz des Ladedruckregelventil bei Vollgas ca. 90%. Diese Einstellung hatte ich aus einem Thread von Rainer entnommen den er dort als Tipp eingestellt hatte. Was ich nicht ganz verstehe ist das ich jetzt im unteren drehzahlbereich bis 2000 U/min immer über dem Soll liege. Ab 1900 habe ich vollen ladedruck der sich auch fast ohne Überschwinger bei ca 1.0 bar einregelt. An der schwachen Leistung des Motors hat sich damit aber nichts geändert. Macht der eigentlich zu hohe Ladedruck im unteren Drehzahlbereich was aus? Im Fehlerspeicher ist nichts abgelegt und wenn ich mir die Gruppe 008 anschaue dann ist die Drehmomentgrenze immer die niedrigste mit ca. 42mg/H. Rußgrenze liegt höher und der Fahrerwunsch auch.
Werde mich am WE mal hinstellen und auf eventuelle Verstopfungen der Kraftstoffleitung prüfen und in den Ansaugkrümmer mal reinschauen ob dort große Mengen an Ablagerungen sind.
Reuselkopp
Post18-02-2005, 12:32    Subject: G3 AFN performance loss, I'm stuck! Translating...
[Translating...]
reuselkopp wrote:
Habe mittlerweile den Turbo etwas schärfer gestellt d.h. den Verstellhebel gekürzt. . . Was ich nicht ganz verstehe ist das ich jetzt im unteren drehzahlbereich bis 2000 U/min immer über dem Soll liege.
Tja, die Ladedruckregelung startet AFAIK zunächst mit einem vorprogrammierten Ausgangswert aus einem Kennfeld für Drehzahl, Solldruck und Tastverhältnis.
Wenn damit der Solldruck nicht erreicht wird, wird nachgeregelt - allerdings nicht immer so stark, daß die Abweichung völlig weggebügelt wird.
Das bezeichne ich hier jetzt mal als "weiche" Regelung, wobei ich die Fachbegriffe nicht kenne -> @ Spezis: bitte korrigieren!
D.h. als Restfehler bleibt eine Soll-Ist-Differenz bestehen, deren Größe davon abhängig ist, wie falsch die VTG-Stangenlänge gegenüber dem Normalwert ist.
Zusätzlich ist die Regelstrategie Deines MSG offenbar bis 2000 rpm "weicher" als darüber.
Ich bin derzeit mit der Feinabstimmung meiner VTG-Stangenläge auf das Chiptuning beschäftigt. Offenbar ist die LD-Regelstrategie beim ASZ noch viel "weicher", als ich es vom AFN in Erinnerung habe, d.h. Änderungen der Stangenlänge werden beim ASZ noch weniger ausgeregelt . . . ich glaube, das müßte man mal im VTG-Fachartikel ergänzen.
reuselkopp
Post18-02-2005, 12:53    Subject: G3 AFN performance loss, I'm stuck! Translating...
[Translating...]
macht sich denn die Soll-Ist differenz im unteren Drehzahlbereich in der leistung bemerkbar?
Reuselkopp
Günther
Post18-02-2005, 12:59    Subject: G3 AFN performance loss, I'm stuck! Translating...
[Translating...]Hallo,
wenn der Ladedruck zu niedrig ist, wird auch weniger eingespritzt.
MfG
Günther
Post18-02-2005, 13:02    Subject: G3 AFN performance loss, I'm stuck! Translating...
[Translating...]
MfG
Günther
Hi, er hat aber gesagt, die Rußbegrenzung schlägt nicht zu...
Post18-02-2005, 13:10    Subject: G3 AFN performance loss, I'm stuck! Translating...
[Translating...]
Rainer K. wrote:
MfG
Günther
. . . und "er" ist wohl reuselkopp, der allerdings selbst die Ausgangsfrage gestellt hat . . . nur an wen icon_question.gif
Falls ich gemeint sein sollte:
Ja, wie üblich -> solange die Rußbegrenzung am niedrigsten liegt.
reuselkopp
Post18-02-2005, 13:39    Subject: G3 AFN performance loss, I'm stuck! Translating...
[Translating...]
damit sich hier keiner verbal die birne einschlägt. Mein Ladedruck ist im unteren Drehzahlbereich bis 1900 U/min immer über dem Soll! Ich meine ich habe bereits bei 1200/min einen überdruck von ca. 300mbar.
Frage an alle... sehe ich das richtig das diese Soll-Ist differenz im unteren Drehzahlbereich keinen einfluß auf meine Minderleistung hat?
Reuselkopp
Post18-02-2005, 14:05    Subject: G3 AFN performance loss, I'm stuck! Translating...
[Translating...]
Hi Ulf,
ich hatte eigentlich Günther gemeint.
@reuselkoppViewing profile: reuselkopp: der etwas höhere Ladedruck im Drehzahlkeller sollte egal sein.
Günther
Post18-02-2005, 14:53    Subject: G3 AFN performance loss, I'm stuck! Translating...
MfG
Günther
Hallo Rainer,
OK, aber wer 'schlägt' dann zu?
MfG
Günther
reuselkopp
Post18-02-2005, 15:42    Subject: G3 AFN performance loss, I'm stuck! Translating...
[Translating...]
ich würde sagen es schlägt gar keine Grenze zu! Zumindest die Werte in Gruppe 008, Ladedruck ist auch Super OK und der LMM auch. Jetzt nach dem scharfer stellen des Turbos geht der LMM-Wert erst bei ca. 4300U/min ein wenig in die Knie.
Mein Motörchen ist einfach nur zäh. Aber komischerweise nicht immer, ab und zu aber sehr selten geht die Karre auch mal gut ab (bis zum nächsten schalten) Leider ist es aber nicht reproduzierbar wann wieso weshalb er gerade dann mal gut geht.
Ich meine der Motor hat entweder zuwenig Luft oder zuwenig Sprit. Aber wenn er zuwenig Luft hätte (eventuell durch eine zugeschlammte Ansaugbrücke) dann würde er doch auch rußen. Oder?
Ich werde nachher mit einem Zusatztank im Motorraum mal den Haupttank abklemmen und ohne Filter fahren um zu sehen ob es vielleicht an der Tankanlage+Schläuche liegen könnte. Eher wahrscheinlich nur an den Schläuchen da ich gestern schonmal ohne Tankdeckel gefahren bin aber ohne erfolg.
Reuselkopp
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 1z 2.0 TDI BMM hat Leistungsverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts div. Golf 1J TDI and Gasoline, gradual loss of power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leistungsverlust im Audi 1Z; weiß nicht weiter Diesel Engine Technology
No new posts Performance loss and no one knows what to do On-Board Diagnostics (OBD)
No new posts I can't access the service mode of the Climatronic! Transmission, Chassis, Body & Interior
No new posts Mazda Performance Issues: Air Temp Sensor Problems Diesel Engine Technology
