Increase Starting Amount 2.5 TDI AAT (96)
saxi
Post17-09-2002, 19:20    Subject: Increase Starting Amount 2.5 TDI AAT (96) Quote
hello!
I read the post about how to increase the starting amount for a TDI. Now my question is: how exactly does that work with an AAT, and in what increments can you increase the amount? 1, 10, or 100? Which value makes sense?
Please provide information, Martin.
Translated on 23-10-2026, 23:17.
Michael II
Post18-09-2002, 7:55    Subject: Increase Starting Amount 2.5 TDI AAT (96) Quote
First, perform the login procedure using the login code (for the engine control unit).
Then, adjust the value of the adaptation channel using the "Function Adaptation" option.
The step size is 1. The maximum and minimum values vary from one STG to another.
Tschüss
Michael II
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Increase Starting Amount? Diesel Engine Technology
No new posts Increase initial fuel quantity with VAG-COM on A6 V6 TDI Diesel Engine Technology
No new posts Boost Increase for ALH Engine - Help Needed! Diesel Engine Technology
No new posts Increase idle speed with VAG-COM? Diesel Engine Technology
