Golf iV TDI Klimakompressorkupplung gebrochen | Posts 16+
Go to page: Previous  1, 2
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post28-03-2005, 8:58    Subject: Quote
@JulianViewing profile: Julian
"Cold oil" doesn't exist; you probably meant silicone oil in this case.
Based on what I've read here, there's something called "cold oil," or at least that's the term used for it.
Or am I wrong about this?
Translated on 28-10-2026, 7:21.
Max d. Ä.
Post28-03-2005, 9:57    Subject: Quote
The oil exists and is probably called 'refrigerant oil.'
Just take a look here.
/viewtopic.php?t=3475#Function
Max.
Translated on 28-10-2026, 7:22.
golfschrauber1981
Post28-03-2005, 15:37    Subject: Quote
To be precise, the friendly greeting is:
Refrigerant compressor oil (e.g., part number: G 052 154 A2).
It should actually mean that the mechanic should only add the amount of oil that the device has separated out, because a significant portion remains in the air conditioning compressor and the other components.
That's exactly how I know it.
When taking measurements for a refill, there is often too much oil in the system, which can potentially damage or destroy the equipment.
Translated on 28-10-2026, 7:23.
Varianti
Post28-03-2005, 19:46    Subject: Quote
'The disc is also broken on my unit. It's very annoying because you either need a complete compressor from Bosch or a magnetic coupling from VW, and both are quite expensive.'
Solution: Salvage a compressor from a junkyard. I found one from a Golf II where the clutch disc fit (compressor from the company Sanden). It cost me 10 EUR, as the compressor was already broken. The disc can be replaced even when it's installed (by removing the compressor without disconnecting the lines) in at least the Golf III. The only problem is that you need a special puller with a 1/4-inch thread to remove the disc from the donor part. However, I had it done for free at a climate control shop that specializes in stationary air conditioning systems. Finally, you just need to install it precisely, because the disc must have only about 0.5 mm of clearance to the clutch, otherwise the metal plates will break again.
Translated on 28-10-2026, 7:24.
No new posts Document A2 8Z0 MJ 2003, broken rear spoiler Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 Serpentine Belt Tensioner Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Rear Wiper Motor Leak: Broken Tube Transmission, Chassis, Body & Interior
No new posts Broken 1.9 TDI AFN Camshaft: Causes & Fixes Diesel Engine Technology
No new posts Pierburg MAF Sensor Failure: Troubleshooting Diesel Engine Technology
No new posts Broken Window Regulator: What to Do? Transmission, Chassis, Body & Interior
