I have a big problem: 5 error messages.
Intake air temperature: open or shorted to B+.
Diesel temperature: open circuit or short circuit to B+.
Coolant temperature: open circuit or short circuit to B+.
Accelerator pedal sensor: implausible signal.
Brake light switch monitoring.
The engine has an idle speed that is too high, approximately 1200 RPM.
The Gaspoti display shows the 0-100% readings correctly. The intake air temperature shows approximately
8 degrees Celsius, while the diesel and water temperatures show approximately -6 degrees Celsius (which is already incorrect!).
"When I press the brake and clutch pedals simultaneously, all three sensors show readings below -20 degrees."
As far as I can tell, the three sensors – the throttle position sensor, the clutch switch, and the brake switch – along with some other components, are connected to the same ground point on pin 33 of the control unit.
"Shouldn't the potential be the same as the battery's negative terminal? I can only explain this with a ground fault. And according to my multimeter, there's about 10 megaohms of resistance between the sensor's ground and the battery's negative terminal."
I've successfully measured continuity between the individual components (donors and switches), but not yet to the control unit (STG).
