Acceleration Problem: AFN Engine Troubleshooting
paco
Post30-03-2005, 21:47    Subject: Acceleration Problem: AFN Engine Troubleshooting Quote
Hello everyone,
After having thoroughly researched technical articles and search results, I haven't found any reports with an identical symptom pattern. My A4 with 110 hp has recently started acting up. When accelerating, the engine normally pushes forward up to about 2200 rpm; then it seems to 'explode' (more so than before). After a brief second, it regulates back down and continues to accelerate somewhat worse than normal. Could this be related to the VTG (variable turbine geometry), even though the turbocharger adjustment is smooth, the hoses are tight and not kinked? Or could a faulty mass airflow sensor (MAF) also cause such a symptom pattern? Otherwise, the car actually drives normally; there's no excessive soot or anything like that.
Thank you.
paco
Translated on 25-07-2026, 7:07.
dieselpaul
Post30-03-2005, 23:21    Subject: Acceleration Problem: AFN Engine Troubleshooting Quote
It was the same with my adoption!
LMM is awesome!
Sure, here's the translation:
'Hello.'
m
Translated on 25-07-2026, 7:09.
Post31-03-2005, 0:04    Subject: Acceleration Problem: AFN Engine Troubleshooting Quote
It would be useful to either a) test a different mass airflow sensor or b) check the actual mass airflow values.
It could also be something else. -> Read the error memory.
paco
Post31-03-2005, 0:13    Subject: Acceleration Problem: AFN Engine Troubleshooting Quote
@Rainer K.
According to the workshop, there's nothing in the error memory, and I already asked if they could try installing a different mass airflow sensor (MAF) just for testing purposes - but they refused. Their exact words were: 'What do you want? The car is running!' icon_eek.gif
Well, maybe I can borrow something like that privately sometime.
paco
Translated on 25-07-2026, 7:10.
syncro peter
Post31-03-2005, 8:01    Subject: Acceleration Problem: AFN Engine Troubleshooting Quote
To know that, I would need to know where you are from icon_biggrin.gif.
Translated on 25-07-2026, 7:11.
Varianti
Post31-03-2005, 17:49    Subject: Acceleration Problem: AFN Engine Troubleshooting Quote
Try cleaning the LMM (likely referring to a mass airflow sensor) with brake cleaner first. It sometimes works wonders.
A simple swap of the mass airflow sensor (MAF) with a friend once helped me. After that, I had no more problems, and neither has he to this day. Strange, but true.
macs
Post31-03-2005, 20:10    Subject: Acceleration Problem: AFN Engine Troubleshooting Quote
Air mass meters are no longer that expensive; for example, at Stahlgruber, they cost around €75, which is before your discount.
New part, not a replacement.
If so, then choose Pierburg 7.22684.08.0 (Stahlgruber number 456 6124). icon_wink.gif
I hope I'm not stepping on anyone's toes with these statements. If I am, please let me know, and I will refrain from making similar comments in the future.
I just have one of those things lying on the table right now.
Hope this helps you.
Translated on 25-07-2026, 7:13.
No new posts Vibration at Acceleration: Causes & Fixes General Tips
No new posts Automatic 01N with AFN Engine - Problem with the Gearbox ... General Tips
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts Rough idling when accelerating; incorrect PD element?? Diesel Engine Technology
No new posts Problem beim Ausbau der ESP VP37 beim AEL-Motor (A6 2,5 TDI) Diesel Engine Technology
This topic is locked, you cannot edit or reply. Engine Jerk with DPF: Causes & Solutions Diesel Engine Technology
No new posts BMP ruckelt beim Beschleunigen Diesel Engine Technology
