Audi 100 2.5 TDI, engine code ABP, issues after chip tuning
KimR
Post10-05-2005, 13:24    Subject: Audi 100 2.5 TDI, engine code ABP, issues after chip tuning Quote
'The following concerns a specific case.' Bosch 0281001092.
I've been trying it out all day. 'Even after the engine has warmed up, the power delivery is still erratic, with strange, brief 'stuttering' or 'power dips' occurring between 2500 and 3500 RPM.'
They only occur when accelerating fully, and they last only milliseconds.
I was wondering if this could be coming from the RSW Poti. It swings out further with a higher fuel quantity and appears in the area where coal residue accumulates. And that's why there's a potential for poor contact with the slide and the carbon layer.
I'm also seeing a value for 'KF' in the MotorFile starting at address $0781F. I suspect it's a fuel quantity limitation, but my car doesn't have an air mass sensor (and I can't find it mechanically either). Could it be related to boost pressure?
Could someone guide me in the right direction?
I can provide you with Eprom files. Send a PM.
I am grateful for any input!
Andi aus dem Ösiland
Post11-05-2005, 22:20    Subject: Audi 100 2.5 TDI, engine code ABP, issues after chip tuning Quote
Could you please send me the files (both the original and the tuned versions)? I'll take a look and see if I notice anything.
Have you covered everything about pump voltage?
Andi.
KimR
Post11-05-2005, 22:38    Subject: Audi 100 2.5 TDI, engine code ABP, issues after chip tuning Quote
I've tried various things, for example, just adjusting the pump voltage and boost pressure.
With the same result. It seems like something is happening with larger quantities.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Relais-Klackern" nach Startphsae / Kaltstartprobl Diesel Engine Technology
No new posts 2.0 TDI CR (CAGA) bockt "nur" nach Kaltstart Diesel Engine Technology
No new posts "Airbag-Warnung" nach Sitzverstellung Transmission, Chassis, Body & Interior
No new posts Engine Noise After Timing Belt Replacement Diesel Engine Technology
