Document: Flange, Wave, Gearbox 012 and 01A (Solution)
Michael II
Post08-10-2002, 17:56    Subject: Document: Flange, Wave, Gearbox 012 and 01A Quote
012-, 01A Flange, moves out of the gearbox, shaft seal leaking
Cause:
a)
Incorrectly installed compensating gear in the differential. It is missing the nut for the retaining ring on the flange.
b)
The retaining ring is missing on the flange.
Procedure:
When there are leaks at the flange face, it is necessary to check whether the flange face is securely seated and whether the locking ring is present.
a)
If the flange stop protrudes even though the locking ring is present, the gearbox must be replaced.
b)
If the fuse ring is not present, it should be installed with part number 012 409 413 A and the flange pivot should be checked. Replace the O-ring!
Tschüss
Michael II
Ratings - Document: Flange, Wave, Gearbox 012 and 01A
No new posts Gear oil change T6 manual transmission Troubleshooting & Guides
No new posts A4/A6 Docs: Idle Vibration Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8D: Documenting Performance Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi S5 8T, 4.2L Manual Transmission, ACC Coding On-Board Diagnostics (OBD)
No new posts AFN TCU: Automatic & Manual Transmission Control On-Board Diagnostics (OBD)
No new posts Engine control unit cannot be coded for manual transmission On-Board Diagnostics (OBD)
No new posts Interessante Doku zum 1.9 TDI Motor Diesel Engine Technology
