AFB Motor Suction Nozzle
RAF1
Post10-06-2005, 11:20    Subject: AFB Motor Suction Nozzle Quote
Does anyone know if the intake manifolds of the AFB have the internal valves (e.g., as in the Mercedes 220 CDI)?
Rafael
datsun
Post11-06-2005, 13:12    Subject: AFB Motor Suction Nozzle Quote
Hello Rafael,
If you mean a Schrader valve, the V6 TDI AFB or AKN does not have one.
I hope it was helpful.
Rainer
RAF1
Post13-06-2005, 8:13    Subject: AFB Motor Suction Nozzle Quote
It refers to a distribution charging air duct, which would have several flaps (1 per cylinder) inside.
Maintaining a stable boost pressure is beneficial for the CDI engine.
Greetings
Rafael
christians
Post13-06-2005, 13:06    Subject: AFB Motor Suction Nozzle Quote
are these valves not for controlling the twist? (Relatively) a lot of twist at low throughput, (relatively) little twist at high throughput.
But I haven't seen anything about that in the AFB either.
Gruß Christian
RAF1
Post13-06-2005, 14:28    Subject: AFB Motor Suction Nozzle Quote
Thank you.
Second question.
Can the AKN motor's injector be mounted in AFB?
Rafael
Post13-06-2005, 14:31    Subject: AFB Motor Suction Nozzle Quote
If, then the timing valves are located in the cylinder head.
I'll check the SSP for the V6 TDI.
The suction tube has none, because otherwise there would be 6 connections or waves to see here:
 File size:  17.82 KB
 Viewed:  1555 times
No new posts Development of the 1.9 l TDI Engine Technical Articles
No new posts Geräusche beim abstellen des Motors Diesel Engine Technology
No new posts VW 1Z Engine ESP Tax Signal (VP37) On-Board Diagnostics (OBD)
No new posts Volvo D5 Diesel Engine Technology Diesel Engine Technology
This topic is locked, you cannot edit or reply. Can You Determine Engine Mileage? On-Board Diagnostics (OBD)
