Water in Trunk: Causes & Solutions
Stephan_Reisch
Post14-01-2004, 10:43    Subject: Water in Trunk: Causes & Solutions Quote
Hello colleagues,
'Recently, I've been experiencing water inside the tailgate (of my Passat TDI Variant, manufactured in 1999, 115 hp) after rain or after going through a car wash. When I open the tailgate, the water then drips out from the trim and into the interior. Has anyone else experienced a similar problem, and do you know what the possible cause might be?'
Best regards, Stephan.
Translated on 28-09-2026, 13:38.
Dan.jel
Post14-01-2004, 11:22    Subject: Water in Trunk: Causes & Solutions Quote
Perhaps it's only happening after using the wash water for the rear hatch?
Then the hose to the splash guard is probably defective...
Translated on 28-09-2026, 13:39.
Post14-01-2004, 16:05    Subject: Water in Trunk: Causes & Solutions Quote
The alternatives would be either a detached hose connector in the line leading towards the tailgate, or a detached hose directly on the wiper motor.
This sometimes happens when the rear wiper's nozzle has been running for a while. The water then runs onto the tailgate lock and can potentially damage the contact. This can lead to a false alarm from the vehicle's alarm system, and often also causes problems with the central locking system.
Translated on 28-09-2026, 13:40.
Stephan_Reisch
Post15-01-2004, 7:55    Subject: Water in Trunk: Causes & Solutions Quote
Hello colleagues,
I will check it, but I don't think it's a leaking hose. If it were, it would smell/taste like windshield washer fluid. However, it has no odor or taste.
Translated on 28-09-2026, 13:41.
poeler
Post28-11-2004, 15:05    Subject: ;): I used to have it until yesterday Quote
... it was due to the poetry on the handles used to open the tailgate (under the plastic, where the license plate lights are located).
Whenever it rained, water would leak from the trim and run down into my neck icon_sad.gif.
If you want to repair it yourself, order 3 of the seals; later you will know why icon_smile.gif. It costs 1.40 per piece.
Translated on 28-09-2026, 13:42.
Stephan_Reisch
Post22-06-2005, 6:58    Subject: Problem Solved: Simple Solutions & Tips Quote
The poem was by Wars, as my colleague correctly suspected. Thanks again, best regards, Stephan.
No new posts Handwashing on the go, without water General Tips
No new posts Doku Polo 9N, water accumulates in the footwell during he... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tapping noises, Audi A3 8P rear hatch/trunk lid Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Does the A6 C4 Avant rear door fit the rear door? Transmission, Chassis, Body & Interior
No new posts Water in the lock... Transmission, Chassis, Body & Interior
No new posts Water Damage ASZ: Causes & Prevention Diesel Engine Technology
No new posts Water = 100°C at the source, but only 13°C outside!! Diesel Engine Technology
