MONCHI Guest
11-10-2002, 13:40 Subject: LMM failure on Ibiza TDI AFN (81kW)? |
I'm having the following problem:
My car has significantly more power when it's cold, and it doesn't really start performing well until around 3000 RPM. I have a power box from KW-Systems installed, and the potentiometer is turned all the way up. I called them about it, and they told me that my mass airflow sensor (MAF) might be defective.
How can I check that?
Thank you for your help!
Monchi.
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
11-10-2002, 14:07 Subject: LMM failure on Ibiza TDI AFN (81kW)? |
First, I would read the error codes. If there is no information provided, you should perform a measurement run (values are in the error database).
The topic of LMM has already been discussed quite frequently here. Just search for it... Tschüss
Michael II
