Golf V PD: Reset WIV (Water Injection Valve)
poppel
Karma: +1 / -2   Thank you, like it!
Post17-10-2005, 13:07    Subject: Golf V PD: Reset WIV (Water Injection Valve) Quote
Unfortunately, the search function didn't yield any results. I want to reset the WIV display in my Golf V PD. Does anyone have any information about that?
Thank you!
Translated on 27-08-2026, 10:10.
Post17-10-2005, 14:58    Subject: Golf V PD: Reset WIV (Water Injection Valve) Quote
vagtuning
Post17-10-2005, 17:08    Subject: Golf V PD: Reset WIV (Water Injection Valve) Quote
Set address word 17 (combination) adaptation channel 02 to value 00 and save.
It should actually work.
Translated on 27-08-2026, 10:11.
poppel
Post17-10-2005, 18:03    Subject: WIV Reset: How to Reset Your WIV Quote
The page https://community.dieselschrauber.org/en/viewtopic.php?t=6076
I already found that, but it doesn't mention the Golf V model from 2005 anywhere.
Thank you.
*It should actually work.*
That's a good starting point. Thank you.
goettmann
dieselschrauber likes this.
Post18-10-2005, 6:47    Subject: WIV Reset: How to Reset Your WIV Quote
Das ist schon mal ein Ansatz. Thank you.
Why didn't you do it the way described in the article above?
The same procedure applies to all WIV vehicles, just as 'vgatuning' mentioned.
Please check if the WIV (likely referring to a specific system or function) is active after resetting channel 02. It's possible that a fixed interval is then activated. This is how it works in the Touran, at least (I haven't yet had a chance to examine the G5 module).
I'm not sure about the channel for oil quality; it should be 45 (but if not, it's channel 4).
See also: https://community.dieselschrauber.org/en/viewtopic.php?t=10656
Translated on 27-08-2026, 10:13.
poppel
Post19-10-2005, 23:49    Subject: Bingo: Play Online & Win Big Prizes! Quote
Great, thanks! That's perfect!
Is there a list that includes all the channels and their meanings? That would be great. icon_biggrin.gif
Translated on 27-08-2026, 10:15.
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Golf TDI: Stuttering When Coasting to a Stop Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Where is the thermostat located on a TDI BLS Golf 5? Diesel Engine Technology
