Front Axle Noise: Causes and Solutions
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
schnuffelvieh
Post08-03-2006, 16:49    Subject: Front Axle Noise: Causes and Solutions Quote
Okay, so it's happened to me too.
After the 'harsh' winter storms and the supposedly very cold winter, I'm now hearing some rather heavenly noises coming from my front axle.
I initially thought it might be a faulty shock absorber or salt on the tire treads, but that's not the case.
Since my 4B is equipped with Xenon headlights, there are axle sensors located on the axles. It's hard to believe, but it's true: these small, dirty things make a noise like a faulty shock absorber.
So, you should probably encounter this issue as well: First, check the wheel speed sensors. A little WD40 might provide a quick, but temporary, fix. However, a new wheel speed sensor will likely need to be installed in the near future.
Basti.
Translated on 14-09-2026, 19:32.
joegolf
Post09-03-2006, 9:57    Subject: Front Axle Noise: Causes and Solutions Translating...
[Translating...]
Hatte ich auch schon: icon_sad.gif
/viewtopic.php?t=10444&highlight=
Golf 7 GTI
schnuffelvieh
Post09-03-2006, 11:36    Subject: Front Axle Noise: Causes and Solutions Translating...
[Translating...]Und bisher ist Ruhe oder muckt es ab und an mal wieder rum?
joegolf
Post09-03-2006, 13:57    Subject: Front Axle Noise: Causes and Solutions Translating...
[Translating...]
Bislang Ruhe, muss mal abwarten, bis wieder trockenes Wetter kommt. Allerdings werde ich das Gelenk beim nächsten Reifenwechsel nachschmieren.
Golf 7 GTI
schnuffelvieh
Post09-03-2006, 14:01    Subject: Front Axle Noise: Causes and Solutions Translating...
[Translating...]Und das ist lediglich ein Kugelkopfgelenk und man kann es 'einfach' auseinandernehmen? Das wäre natürlich nicht schlecht icon_lol.gif
joegolf
Post09-03-2006, 18:29    Subject: Front Axle Noise: Causes and Solutions Translating...
[Translating...]
Und das ist lediglich ein Kugelkopfgelenk und man kann es "einfach" auseinandernehmen? Das wäre natürlich nicht schlecht icon_lol.gif
Auseinandergenommen hab ich das nicht, nur Silikon drauf (kriecht überall rein) und hin- und herbewegt.
Das ist so ein Gummi-Verbundteil.
Golf 7 GTI
schnuffelvieh
Post09-03-2006, 21:37    Subject: Front Axle Noise: Causes and Solutions Translating...
[Translating...]Okay, dann werde ich mich da mal dranbegeben icon_smile.gif ist ja bald Wochenende icon_lol.gif
No new posts Quietschen Vorderachse links (Golf4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku 2D bis 03/2001 Klappergeräusche Vorderachse Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Phaeton Noise: Front Axle 3D2 Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Knarren und Widerstand im Bremspedal Transmission, Chassis, Body & Interior
No new posts Knarren der Schraubenfeder nach Stoßdämpferwechsel vorn Transmission, Chassis, Body & Interior
No new posts 4-Motion Rear Noise? KW GmbH Fixes It! Transmission, Chassis, Body & Interior
No new posts T4 front axle Upload
