Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1142 Karma: +38 / -0 Location: Wien 2001 Audi A2  Premium Support
13-11-2002, 19:07 Subject: How to reset the service indicator on an Audi A3? |
Hello you diesel enthusiasts out there.
I'm having a problem with my Audi A3 from 1997; it seems that my...
The oil level warning light (not the oil pressure light) always flashes when starting the engine.
And since I'm a DIY enthusiast like yourselves, and I don't feel like...
to always make a pilgrimage to the friendly ones.
I would be grateful if someone could tell me.
How can I return this good item?
Or does it work like it was described in a thread about the Volkswagen Golf 3?
will?
Sure, here's the translation:
"Cu, Sevi" translates to "Love, Sevi" in English. It is a common way to sign off a letter or email in Turkish.
Translated on 18-07-2026, 18:08.
Profile PM Garage |
Uwe Profi-Schrauber
Joined: 04/15/2002 Posts: 1004 Karma: +5 / -0 Location: Westerwald
13-11-2002, 19:39 Subject: How to reset the service indicator on an Audi A3? |
Hi!
I think only the Audi dealer can help you with the 1997 model. If you ask nicely, they might do it for you free of charge.
Starting at 99, you can reset it via the instrument cluster.
Uwe
Translated on 18-07-2026, 18:10.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
13-11-2002, 22:24 Subject: Funny... |
...what do you always mean by "defer service message"?
In the owner's manual for my A3 from 7/1998, it explains how it works  .
Profile PM WWW Garage |
Uwe Profi-Schrauber
13-11-2002, 22:49 Subject: How to reset the service indicator on an Audi A3? |
Hi Rainer!
"That doesn't work on all models. I believe it doesn't work through the buttons starting with model 99 or 98. Is 7/98 already model 99?"
Uwe
Translated on 18-07-2026, 18:11.
14-11-2002, 8:02 Subject: How to reset the service indicator on an Audi A3? |
@ Rainer: If you know why, then tell me.
Or is that a secret?
Translated on 18-07-2026, 18:12.
Profile PM Garage |
14-11-2002, 10:29 Subject: How to reset the service indicator on an Audi A3? |
Tagessuppe wrote: | @ Rainer: Well, if you know why, then why don't you tell me?
Or is that a secret? |
That's because I have to look it up in the instruction manual myself. If it's in the instruction manual, then anyone can read it themselves.
For those of you who didn't see it written down: I'll take a look during my lunch break.
14-11-2002, 17:07 Subject: How to reset the service indicator on an Audi A3? |
The operating manual "Operating the Instrument Cluster" states, in the section "Service - Interval - Display" on page 60, something to the effect of the following:
Inside the cockpit, there are two buttons: one for setting the clock (1) and another for the trip odometer (2).
- Ignition off.
- (2) Press and hold, then turn the ignition on.
- (1) Move to delete 'service OEL'.
- (2) Press the button; "service INSP" will appear.
- (1) Drag to delete.
Translated on 18-07-2026, 18:14.
15-11-2002, 7:58 Subject: How to reset the service indicator on an Audi A3? |
Great, thanks Rainer. You were a big help to me.
I'm going to try it out today.
What A3 do you actually have? Is yours modified or original?
Thanks and greetings, Sevi.
Translated on 18-07-2026, 18:15.
Profile PM Garage |
Juergen Guest
15-11-2002, 9:16 Subject: How to reset the service indicator on an Audi A3? |
Hey everyone!
I would like to add to what Rainer said that the time setting knob needs to be pulled for about 2 seconds until three dashes appear on the display.
This should (without guarantee) work for vehicles manufactured between 1996 and 1999. From 1999 onwards, it is only possible via the diagnostic connector. (Source: H.R. Ezoldt, 'So wird's gemacht,' Volume 110).
Best regards, Jürgen.
Translated on 18-07-2026, 18:16.
Uwe Profi-Schrauber
15-11-2002, 9:29 Subject: How to reset the service indicator on an Audi A3? |
Juergen wrote: |
This should (without guarantee) work for vehicles manufactured between 1996 and 1999. From 1999 onwards, it is only possible via the diagnostic connector. (Source: H.R. Ezoldt, "So wird's gemacht," Volume 110).
Um, isn't it actually the other way around? On my 2000 A4 and A3 models from 1999, manufactured in 2000, it works through the buttons...
Uwe
Translated on 18-07-2026, 18:17.
15-11-2002, 9:58 Subject: How to reset the service indicator on an Audi A3? |
Tagessuppe wrote: | | What A3 do you actually have? Is yours modified or original? |
"Hey, it's the 'standard' version, neither the sport nor comfort trim, with an AHF engine and manual transmission, and a custom-made boost gauge. Pretty original..."
Translated on 18-07-2026, 18:18.
Juergen Guest
17-11-2002, 9:45 Subject: How to reset the service indicator on an Audi A3? |
As mentioned, the source is a do-it-yourself book. It worked through the buttons on my A3 from 1998, but it didn't work on my A4 from 2000.
Translated on 18-07-2026, 18:19.
