Getriebe umcodiert und nichts gemerkt? | Posts 16+
Go to page: Previous  1, 2
rinderwahnsinn
guste100 likes this.
Post07-09-2005, 11:27    Subject: Quote
...but probably only because, at higher engine torque, more power is lost in the impeller than at higher speeds and lower torque.
Unfortunately, at that moment, the torque converter is not engaged, and the AG4 transmission, at 2000 RPM with the torque converter clutch disengaged, will either open the clutch or immediately downshift to 3rd gear (also with the torque converter clutch disengaged).
And that's at 80 km/h, with the engine approaching its peak torque.
Instead of utilizing the potential motor torque without losses from a torque converter, it actually creates that torque, thereby increasing fuel consumption and degrading driving performance.
With all due respect, but VAG has once again proven itself to be completely incompetent. Even fully hydraulic transmissions (i.e., without any electronics) perform better.
@Georg-TDI
The reason the coding isn't working is related to the software version. Your transmission has version 3xxx, which operated differently. Unfortunately, versions 4xxx and above no longer differentiate between 'Sport' and 'Economy' modes.
Translated on 18-10-2026, 3:07.
WarLord
Post09-09-2005, 15:49    Subject: Quote
With all due respect, but VAG has once again proven itself to be a complete failure. Even fully hydraulic transmissions (i.e., without electronics) perform better.
Where do other automatic transmissions excel? The only transmission that does it better is a manual transmission, because it requires a skilled driver.
Best regards, WarLord.
Translated on 18-10-2026, 3:09.
Post09-09-2005, 16:26    Subject: Quote
I actually wanted to show you this.
http://www-dt.e-technik.uni-dortmund.de/~otte/dieseltdi19.gif
Georg-TDI
Post12-09-2005, 7:34    Subject: Quote
The reason the codings are not working is related to the software version. Your transmission has version 3xxx, which operated differently in many ways. Unfortunately, versions 4xxx and above no longer differentiate between 'Sport' and 'Economy' modes.
@rinderwahnsinn
Thank you.
That was my assumption as well, but it's good that you can confirm it.
Best regards, Georg.
Translated on 18-10-2026, 3:10.
corryfan
Post23-02-2006, 0:33    Subject: Quote
Does anyone have any information about the coding procedure for the AG5 TT5 (Tiptronic) transmission in a 3BG Passat?
A nice label file for the measurement data would also be great!
Translated on 18-10-2026, 3:11.
Ross-Tech-Support
Post23-02-2006, 15:30    Subject: Quote
@corryfan
Part number, software version, and current coding?
corryfan
Post23-02-2006, 16:33    Subject: Quote
@sebastian
A coding table or a table for channel adjustments would be great. I currently have the following information available:
3B0 927 156 S AG5 01V 1.9l-PD RdW 2224
Passat 3BG, first registration 02/2004.
series encoding: 00103
Tried sports coding before (it works): 01103. Workshop code: 05311.
I just want to understand what I'm doing! That's why I'm looking for 'plain language' explanations of the individual code sections.
or even for the engine; --)
038 906 019 KD, G000AG 4897, Engine Code: AVF 96KW PD.
Thanks in advance! I haven't found anything about this here, except for a label file from a Phaeton that Uwe has. Do you think that will work?
http://www.ross-tech.com/vag-com/download/label-files/3D0-927-156.lbl
Translated on 18-10-2026, 3:12.
olkoo
Post24-02-2006, 7:54    Subject: Quote
Hello.
Yes, a breakdown of the code would be very interesting.
I also successfully switched to the 01103 prefix.
However, I would like to disable this dynamic control program because it is very annoying.
3BG, 2003, AVF, EYF.
olli
Translated on 18-10-2026, 3:14.
corryfan
Post07-03-2006, 12:33    Subject: Quote
Does anyone have anything else to add?
Ross-Tech-Support
Post19-03-2006, 14:05    Subject: Quote
corryfan wrote:
@sebastian
Encoding table...
It is known/available, but there are variations between different model years.
corryfan wrote:
Oh yeah, I didn't find anything about this on openobd.org, except for a label file from a Phaeton belonging to Uwe. Will that work?
Yes, depending on the make and model year, there are smaller and larger differences, so it's better to wait until a proper version is available.
Translated on 18-10-2026, 3:15.
Schlüpferhüpfer
Post19-03-2006, 19:58    Subject: Coding 01103: A Comprehensive Guide Quote
Regarding the remapping to 01103, here's some brief feedback: icon_surprised.gif reduced "sloshing" losses, slightly shorter shift times, maximum speed (Vmax) is approximately 10 km/h lower, according to VAG-COM, there's a good 20 Nm more input torque at the TT (transmission), the shifting behavior and shift points remain unchanged with DSP (Dynamic Shift Program), and approximately 1 liter less fuel consumption on reference routes (city, country road).
A previously undiscovered economy code for the 01V would, however, be of great help to my progress. new_cry.gif
(ATF III and filter replaced according to GERI's instructions at 30,000 km).
3BG Variant V6 TDI TT5 Comfortline Bj. 02
Translated on 18-10-2026, 3:17.
Ross-Tech-Support
Post19-03-2006, 20:00    Subject: Quote
Schlüpferhüpfer wrote:
An economy code that has not yet been discovered for the 01V would, however, be of great benefit to my journey.new_cry.gif!
As far as I know, there is no economy code available for the 01V/01J models.
But I'm seriously wondering how you arrive at these values.
Code:
0?xxx: Tiptronic Installation
0 = Tiptronic Buttons/Paddels not installed
1 = Tiptronic Buttons/Paddels installed
Translated on 18-10-2026, 3:18.
Schlüpferhüpfer
Post19-03-2006, 20:23    Subject: Quote
@ Sebastian
This has been extensively discussed in various forums - you are certainly better informed about this matter icon_eek.gif.
And: You can feel free to try both encodings on my tractor sometime - I'm often in your area. icon_redface.gif
Translated on 18-10-2026, 3:19.
Ross-Tech-Support
Post19-03-2006, 20:34    Subject: Quote
I'm just surprised that a single piece of information can have such a significant impact... icon_wink.gif
No new posts TDI Exhaust Tuning: Just for Show? Technical Articles
No new posts Document LT 28, Transmission Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts LWR Error: Unrecoverable Memory Corruption (Solved) On-Board Diagnostics (OBD)
No new posts The display in the instrument cluster is not showing anyt... On-Board Diagnostics (OBD)
No new posts Coolant Leak: Workshop Can't Find It? Diesel Engine Technology
No new posts The climate control display is no longer showing anything. On-Board Diagnostics (OBD)
