02J Gearbox Shift Lever: What is it for?
Post13-06-2006, 8:23    Subject: 02J Gearbox Shift Lever: What is it for? Quote
The EBF (which should be a 02J) in the Leon has a lever located near the gear stick.
What is this for?
 File size:  33.79 KB
 Viewed:  1626 times
Translated on 14-10-2026, 22:29.
Post13-06-2006, 9:09    Subject: Gear Lever Linkage: What is it for? Quote
dieselmartin wrote:
The EBF (which should be a 02J) of the Leon has a lever near the gear stick.
Hi Martin,
AFAIK, this allows you to fix the position of the shifting lever (by aligning a hole in the lever with the end of the shaft, allowing the lever to be inserted), which can be used to adjust the shifting mechanism.
Release the cables, secure the gear stick with a special tool, and then reattach the cables.
Pull the lever on the gearbox, release the gear stick, and you're done (or how do you say it in the Palatinate icon_wink.gif)?
Translated on 14-10-2026, 22:30.
No new posts Lupo 6X1 MJ 2002: Broken Flap Lock Lever Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts GRA Lever: €86 - Is It Worth It? Diesel Engine Technology
No new posts Cruise control in A3 8P using a Golf 5 lever Diesel Engine Technology
No new posts GRA lever installed - return ring clicks Transmission, Chassis, Body & Interior
No new posts Would it be possible to transfer the GRA lever from the n... Diesel Engine Technology
