Girling 54 Brake Torque: Specs & Performance
Post07-06-2006, 21:06    Subject: Girling 54 Brake Torque: Specs & Performance Quote
HI,
Am I correct in understanding that the entire braking force in the Girling 54 brake is transmitted as shear force through the two "ribbed screws" of the brake pad carriers?
The old VW-II brake design has brake pad carriers that are attached to the wheel bearing housing, which clearly shows how the force is transmitted.
The 54 series comes with either 13-inch solid discs or 20-inch inner-vented discs, requiring two different mounting brackets that are interchangeable. Each bracket is attached with two "ribbed screws M12x1.5x35" and tightened to a torque of 125 Nm.
It's kind of scary to think that those four screws have to hold everything back in a full emergency stop.
Translated on 10-09-2026, 20:25.
golf3schrauber
Post08-06-2006, 6:11    Subject: Girling 54 Brake Torque: Specs & Performance Quote
I'm just wondering how the front axle construction holds up. I would have designed the pivot joint differently.
Are the braking forces not transmitted to the wheel bearing housing through the contact pressure on the braking surface?
Gruss Oliver.
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 10-09-2026, 20:26.
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post08-06-2006, 6:37    Subject: Girling 54 Brake Torque: Specs & Performance Quote
@dieselmartinViewing profile: dieselmartin: Nice photo! icon_cool.gif
"I also see it that way; it's only held in place by those two screws. On the Scirocco2 16V (which has the same brake system), it's even held in place by just two M10 screws with a strength rating of 12, and with a slightly smaller screw spacing. I have no idea what kind of forces would need to be applied to break one of those screws..."
Translated on 10-09-2026, 20:27.
Arno
Post08-06-2006, 8:56    Subject: Girling 54 Brake Torque: Specs & Performance Quote
It kind of scares me that those four screws have to hold up a full stop...
They do, however. And they have been doing so for years, with cars all over the world icon_exclaim.gif.
It also made me raise an eyebrow, but I'm not the only one driving around with such a contraption icon_smile.gif. Wonders of technology........
Perhaps someone with a background in academics could calculate the forces involved.
Translated on 10-09-2026, 20:28.
tdi-schrauber
Post13-06-2006, 20:22    Subject: Girling 54 Brake Torque: Specs & Dimensions Quote
Hello!
dieselmartin wrote:
HI,
Have you ever thought about wheel bolts?
Or the axle guide (ball joint, etc.)?
Here's a thought for those who are anxious: how does the brake pad stay attached to the backing plate?
BYE
TDI mechanics.
Translated on 10-09-2026, 20:29.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Golf Brake Upgrade: Experiences with 256x13 to 256x20 Transmission, Chassis, Body & Interior
No new posts Girling part number 60 Transmission, Chassis, Body & Interior
No new posts VW Golf 3: Front Brake Upgrade Guide Transmission, Chassis, Body & Interior
No new posts Brake Pads Too Big for Girling 54 Calipers Transmission, Chassis, Body & Interior
