Hello.
That pretty much says it all, doesn't it?
That was also a topic I was interested in
Let's see how long the engine will last.
So far, 50,000 km with the coolant issue.
I'm leaning more towards some kind of overarching electrical problem that's also causing the AI to malfunction .
I can rule out an electronics problem - it really gets that hot
Have you already implemented that plateau function for the temperature display...?
My AI already has the 'calmed' version of the temperature display installed.
My current problem is the stuttering/jerking, and how it occurs, or what is causing it and where it's happening.
By the way, the coolant isn't burned; it's pushed out through the exhaust gases.
hb2000
