Label file exists in VAG-COM, but no data!
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Tobi12345
Post14-10-2006, 18:14    Subject: Label file exists in VAG-COM, but no data! Quote
I have VAG-COM version 607.3, and I also have the label files for the respective control units that I am reading, but VAG-COM always says that no label file is available.
Where is the error?
Best, Tobi.
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Ross-Tech-Support
Post14-10-2006, 18:19    Subject: Label file exists in VAG-COM, but no data! Quote
[Options]
Set the debug level to 1.
[Take over]
[Auto-Scan]
Select vehicle.
[Start]
After that, please post the complete car scan results here.
Tobi12345
Post14-10-2006, 18:29    Subject: Label file exists in VAG-COM, but no data! Quote
@ Sebastian
Do you mean setting the error log level to 1?
It currently shows 0 for me.
Ross-Tech-Support
Post14-10-2006, 18:35    Subject: Label file exists in VAG-COM, but no data! Quote
Poorly translated by DRV, but yes, that's what I mean.
Tobi12345
Post14-10-2006, 18:42    Subject: Label file exists in VAG-COM, but no data! Quote
Here's the car scan!!!
VAG-COM Version: DRV 607.3-UD
Saturday, October 14, 2006, 6:40:52 PM.
Vehicle type: 6N - Polo 1995>2002
Scan: 01 02 03 08 17 19 25 35 41 45 46 55
Chassis number: WVWZZZ6NZYY600056
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine - No labels available.
Part Number: 045 906 019
Component: 1.4L R3 EDC 0000SG 1040
Encoding: 00003
Workshop No.: WSC 00788
"1 error found:"
17978 - Engine control unit locked.
P1570 - 35-10 - - - Interrupted.
Readiness: 0 0 X X X
Address 03: Brakes Labels: None
Part Number: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Encoding: 05603
No errors found.
Address 17: Combination instrument. Labels: None.
Part Number: 6N0 920 804 M
Component: COMBINATION INSTRUMENT BOO V05
Encoding: 00132
Workshop No.: WSC 00012
No errors found.
Address 19: CAN Gateway. Labels: None.
Part Number: 6N0 909 901
Component: Gateway K<->CAN
Encoding: 00022
Workshop No.: WSC 00000
No errors found.
Address 25: Immobilizer. Labels: None.
Part Number: 6X0 953 257
Component: IMMO 0004
Encoding: 00001
WVWZZZ6NZYY600056 VWZ1Z0Y0350324
"1 error found:"
01176 - Key
07-10 - Signal too weak - Interrupted.
Okay, please provide the German text you would like me to translate. I will provide only the English translation.
Ross-Tech-Support
Post14-10-2006, 19:18    Subject: Label file exists in VAG-COM, but no data! Quote
Hmm...
Since DRV only provides files from the English original version, the only files that should be included are those for the engine control unit and the CAN gateway. Interestingly, this is not the case. In principle, label files exist for all of the above-mentioned control units.
Is the subfolder /Labels/ present, or is it still named "/Labels.new"?
Are the two files, 04-01.lbl and 045-906-019-AMF.lbl, present in the subdirectory /Labels/?
Tobi12345
Post14-10-2006, 19:49    Subject: Label file exists in VAG-COM, but no data! Quote
The subfolder in the diagnostic tool is called "Label.OLD".
There, you'll find the DRV and User folders, as well as all the labels mentioned, including the two you named.
Ross-Tech-Support
Post14-10-2006, 19:58    Subject: Label file exists in VAG-COM, but no data! Quote
I have no idea why the installation isn't working correctly for you, but there should be a folder named "/Labels/" present. Change the name of the folder Label.OLD to Labels, and then run the same auto-scan again, also with debug level = 1.
Tobi12345
Post14-10-2006, 20:12    Subject: Label file exists in VAG-COM, but no data! Quote
It works!!!
"Thank you!!!!"
Whatever the reason this folder was named that, it works now.
Thank you, Sebastian.
Saturday, October 14, 2006, 8:08:25 PM.
Address 01: Engine, Labels: User\045-906-019-AMF.LBL.
Encoding: 00003
"1 error found:"
Address 03: Brakes Labels: 6X0-907-379.LBL
Encoding: 05603
No errors found.
Encoding: 00132
No errors found.
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Encoding: 00022
No errors found.
Encoding: 00001
"1 error found:"
01176 - Key
No new posts 4Motion keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Allroad Luftfahrwerk - keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Beetle 2004 1.4 BCA - No Label File On-Board Diagnostics (OBD)
No new posts Passat 3C - No keys available On-Board Diagnostics (OBD)
No new posts VAG-Software...SUPER...jedoch viele Fragen! On-Board Diagnostics (OBD)
No new posts Brake pads are still in good condition, but the disc is w... Transmission, Chassis, Body & Interior
