A4 TDI: Engine Not Warming Up? Check Airflow!
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
frankwitten
Post17-12-2002, 20:53    Subject: A4 TDI: Engine Not Warming Up? Check Airflow! Quote
Hello, I'm having a problem. My A4 isn't warming up properly, even though the temperature gauge shows 90 degrees.
I have the impression that the airflow is not sufficient.
Because when I set the air conditioner to automatic mode, I can barely feel any airflow, but when I switch it to recirculation mode, I feel like I'm being blown away.
I know that certain parameters, such as speed and rotation, can be read from the climate control system. Is there also a way to influence the control parameters of the climate control system?
Or perhaps perform a reset?
Translated on 02-09-2026, 3:38.
Albrecht
Post25-12-2002, 16:24    Subject: A4 TDI: Engine Not Warming Up? Check Airflow! Quote
Perhaps the pollen filter is clogged, which is preventing enough fresh air from entering! The fact that there is airflow when the recirculation mode is activated also supports this.
I would like to replace that part; it's located at the front, in the water collection box, underneath the windshield.
Best regards, Albrecht.
Translated on 02-09-2026, 3:39.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
New posts P0401 Error: Low EGR Flow - Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Heizung wird nicht warm Transmission, Chassis, Body & Interior
No new posts Coolant gets hot, interior doesn't Diesel Engine Technology
No new posts AYM V6 Overheating: 2.5L Engine Problems Diesel Engine Technology
No new posts Why is it getting so hot? (Jetta JR) Pöl? Diesel Engine Technology
