Can it be diagnosed manually?
wolfi_b
Post30-05-2005, 8:23    Subject: Can it be diagnosed manually? Quote
Hi everyone!
A friend has a manual air conditioning system in his 6/93 Audi 80 1Z Avant. When it's very hot, it doesn't cool at all, but when it's a little cooler, it works correctly. A week ago, it was refilled, but it didn't help.
I have now gone to troubleshoot and saw in the diagram that a K-line leads to the control unit icon_eek.gif. However, I would be surprised if it is possible to manually diagnose the climate control, or is that actually the case? At least, VAG-COM hasn't found any fault codes.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Uwe@Ross-Tech
Post30-05-2005, 14:37    Subject: Can it be diagnosed manually? Quote
I'm not very familiar with your car, but I still can't imagine that your manual climate control system is diagnostic-capable.
-Uwe-
wolfi_b
Post30-05-2005, 14:39    Subject: Can it be diagnosed manually? Quote
I don't believe it either. But then, what's the point of a K-cable? Strange...
1993 Audi 80 B4 1Z
Ross-Tech-Support
Post30-05-2005, 18:24    Subject: Can it be diagnosed manually? Quote
Also, the manual climate control system can also be diagnosed on the Audi 80 (8C).
wolfi_b
Post31-05-2005, 6:17    Subject: Can it be diagnosed manually? Quote
Really? Have you seen it yourself?
I will try again to connect with the VAG-COM...
1993 Audi 80 B4 1Z
Ross-Tech-Support
Post31-05-2005, 13:13    Subject: Can it be diagnosed manually? Quote
Yes, but not just error codes and measurement groups.
wolfi_b
Post05-06-2005, 18:03    Subject: Can it be diagnosed manually? Quote
Okay, it's actually working!
Labelfile available here: http://download.openobd.org/labelfiles/german/4A0-919-579.lbl
And this was in the error log:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 4A0 919 579 C
Component and/or Version:
Software Coding:
Work Shop Code:
1 Fault Found:
00532 - Supply Voltage B+
07-00 - Signal to Low
Measurement blocks were also unremarkable.
But I'm just as smart as before. However, it was quite cold today, so the climate control worked perfectly. If it's too hot again, the search continues...
1993 Audi 80 B4 1Z
Ross-Tech-Support
Post06-06-2005, 18:00    Subject: Can it be diagnosed manually? Quote
Take a look at the shutdown conditions...
wolfi_b
Post07-06-2005, 5:52    Subject: Can it be diagnosed manually? Quote
Yes, of course. But it still needs to heat up again, and the Audi also needs to be in the country...
1993 Audi 80 B4 1Z
Ross-Tech-Support
Post07-06-2005, 10:56    Subject: Can it be diagnosed manually? Quote
Otherwise, this feature should also support sequential actuator diagnosis, which may be helpful.
wolfi_b
Post07-06-2005, 13:00    Subject: Can it be diagnosed manually? Quote
Hmm..
If I examine the label file, in the first field of the MWB1, I can find the bits representing the shutdown conditions. When I looked at the block, it only had 0.0 on it.
In the label file, it states "requires VAG-COM 402.3 or higher", but I only have 311.2.
Could it be due to this?
1993 Audi 80 B4 1Z
Ross-Tech-Support
Post07-06-2005, 15:32    Subject: Can it be diagnosed manually? Quote
Take a close look, there it says: Target Value: 0 = Not switched off .
wolfi_b
Post09-08-2005, 19:19    Subject: Can it be diagnosed manually? Quote
Hi everyone!
I had the aforementioned vehicle in my hands again today.
So sieht der MWB 1 aus, wenn das Klimagerät nicht funktioniert:
icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema fßr andere Leser nutzlos!
Bitte nutze 'Attachment hinzufĂźgen' bzw. das Upload Forum hier.
/img5/5242/klima7bn.gif" class="responsive" alt="http://img5.
/img5/5242/klima7bn.gif" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">[/URL]
And here is the label file:
[code]001,1,Shutdown conditions,of the compressor (Target value: 0 = not shutdown)
; 1 = Off (Delay after motor start / insufficient or no motor speed)
; 2 = Off (Power Disconnect)
; 3 = Off; Coolant temperature too high
; 4 = Off; (Air conditioner compressor intervention)
; 5 = Off (Belt slip too large/Speed sensor not detected/Incorrect magnetic clutch control unit)
; 6 = Off; (until 12 seconds after kick-down)
; 7 = Off (Kick-Down active)
001, 2, Motor Speed
001,3,Compressor,speed
001, 4, current, Belt slip, Target value: max. 30 %
But what does that tell me now? Voltage interruption?
I was more expecting the coolant temperature to be too high or the pressure to be too high (is that then the shutdown condition for the compressor to intervene?).
I don't know how to interpret the "2.0".
1993 Audi 80 B4 1Z
Ross-Tech-Support
Post19-08-2005, 3:09    Subject: Can it be diagnosed manually? Quote
2.0 = 2 = Power outage
Okay, let's start by checking the power supply and the climate control system, starting with a weak battery.
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM Diagnosis: Is Your VW LT Compatible? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. VAG-COM: Audi 80 B4 TDI Diagnosis (1993) On-Board Diagnostics (OBD)
No new posts Manual air conditioning Transmission, Chassis, Body & Interior
No new posts Manual air conditioning system not working. Transmission, Chassis, Body & Interior
