Golf 4: Right Front Inner Fender Liner
pschaefer
Post17-09-2005, 22:39    Subject: Golf 4: Right Front Inner Fender Liner Quote
"Does anyone have a picture or exploded diagram of the inner workings and surrounding components of the right front fender of a Golf IV? I think that since the workshop replaced said fender, a rubber lip on the headlight and a plastic part at the top where it meets the windshield are missing (both are present on the left side) - but I'm no longer sure what it looked like..."
Translated on 31-08-2026, 12:34.
Blechmann
Post18-09-2005, 11:54    Subject: Golf 4: Right Front Inner Fender Liner Quote
'If something is present on the left side, there's a good chance it was also present on the right side at some point.'
'Your trusted VW dealer has the AKTE system for parts sales, which contains every single part that belongs to your car, and you can check (or have someone check) to see if anything is missing or not.'
'I would simply go to the service master and tell him directly that you believe something is missing. Ask him to show you in the AKTE system or on a similar car that you are wrong.'
Translated on 31-08-2026, 12:35.
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post18-09-2005, 11:58    Subject: Golf 4: Right Front Inner Fender Liner Quote
Here's a picture of the rubber lip. Unfortunately, I don't have an exploded diagram. However, since the structure is the same on both sides, it shouldn't be a problem to compare the parts. There's a plastic cover for the hood hinge, and on the fender, towards the window, there's another plastic cover clipped to the fender.
The part numbers for the covers are 1J0 819 447E and 448 E. Unfortunately, I no longer remember which one is for the right or left side, but the dealer can tell you.
 File size:  26.71 KB
 Viewed:  2249 times
Translated on 31-08-2026, 12:36.
pschaefer
Post18-09-2005, 12:12    Subject: Golf 4: Right Front Inner Fender Liner Quote
The fender was replaced by a local workshop, that's why I asked here icon_smile.gif - Thank you both very much, that helps me a lot!
Greetings and happy (election) Sunday!
Translated on 31-08-2026, 12:37.
wutz
2006 Seat Leon
Post18-09-2005, 21:33    Subject: Golf 4: Right Front Inner Fender Liner Quote
Here's a small tip while you're checking things: There should be two foam blocks in the wheel arch liner, one approximately at mid-height near the door and one centered above the wheel.
Good luck!
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI "Wiring Issues": Golf 3 Engine Control Problem? On-Board Diagnostics (OBD)
No new posts Golf Roof Antenna: Drill & Installation Dimensions Transmission, Chassis, Body & Interior
No new posts Accident Golf III Gti 20 years and "reference points"? Transmission, Chassis, Body & Interior
No new posts Starter motor noise Golf III Diesel Engine Technology
