Engine failures between 1700 and 2200 (diesel)
mhernach
Post19-10-2005, 5:41    Subject: Engine failures between 1700 and 2200 (diesel) Quote
Hello everyone, I really need a vacation.
Okay, seriously now.
While accelerating, it experiences misfires; initially, these occur at 1700-2200 rpm, and it feels like the ignition is being cut off. HOWEVER, IT IS A DIESEL ENGINE. icon_eek.gif
Now it does that across the entire RPM range, starting from 1700 RPM.
Just so you know, I drove it with almost a full tank yesterday, and the problem started after that.
Please help me; do you have any idea what might be the problem?
The engine is a 1Z with 301,000 kilometers on it. The cylinder head was replaced at approximately 270,000 kilometers, and the ESP (electronic stability program) unit has also been changed (with one that has 120,000 kilometers).
Oh yes, I almost forgot, NO ERRORS IN MEMORY.
Translated on 18-07-2026, 9:27.
Post19-10-2005, 7:14    Subject: Engine failures between 1700 and 2200 (diesel) Quote
Mhhh... well, I'm telling you, I bet there's a connection icon_idea.gif. What do you think about air in the system? Do you have a piece of clear diesel hose in front of the ESP? Then take a look and see if it's bubbling at all!
Translated on 18-07-2026, 9:29.
Post19-10-2005, 10:25    Subject: Engine failures between 1700 and 2200 (diesel) Quote
matthiasTDI96 wrote:
What do you think about air in the system? Do you have a piece of clear diesel hose before the ESP? Then take a look and see if there's any bubbling!
If the problem persists after refueling, I would suspect a diesel sludge cloud.
They look particularly beautiful when dancing in almost empty tanks while driving, but then they settle down near any narrow passage or filter, effectively cutting off the supply.
Translated on 18-07-2026, 9:30.
mhernach
Post19-10-2005, 12:45    Subject: Engine failures between 1700 and 2200 (diesel) Quote
They look especially beautiful when dancing in almost empty tanks while driving, but then they settle down in front of some narrow passage or filter and thus cut off the supply.
Okay... but I don't understand why I then have completely normal engine power?!
He would then have to get worse, wouldn't he?
Translated on 18-07-2026, 9:31.
Post19-10-2005, 16:38    Subject: Engine failures between 1700 and 2200 (diesel) Quote
mhernach wrote:
Ah... but I don't understand why I then have completely normal engine power?!
He would then have to do worse, or not?!
Yep, I agree.
Then the familiar "bull market" probably begins with volatile price swings:
Check idle speed control, injection timing / NBF, possibly clean the mass airflow sensor (MAF). icon_rolleyes.gif
Translated on 18-07-2026, 9:32.
mhernach
Post21-10-2005, 5:20    Subject: Engine failures between 1700 and 2200 (diesel) Quote
Yesterday, I finally had some time to take a closer look at my car.
Now the 'thing' is working again, and I can finally...
So, now let's get to the problem:
The problem was with the connector at the fuel injection pump, where my cheap 'tuning' modification was located... I actually wanted to remove the control unit, but then I saw that although the connector seemed properly connected, the contacts were slightly corroded.
I was really frustrated with my Ford, but I'm so glad that nothing was broken.
Translated on 18-07-2026, 9:34.
Post21-10-2005, 7:05    Subject: Engine failures between 1700 and 2200 (diesel) Quote
mhernach wrote:
The connector at the fuel injection pump, where my cheap modification was located, was the problem... I actually wanted to remove the control unit, but then I saw that although the connector seemed properly connected, the contacts were slightly corroded.
Ugh... of course, one doesn't immediately think of something like that when posting in a forum.
Well, it's nice that it's working again icon_smile.gif.
For understanding:
Is it a self-made tuning solution or a purchased device?
Original VAG pump connectors including moisture seals, or self-made connector solutions?
Translated on 18-07-2026, 9:36.
mhernach
Post21-10-2005, 9:13    Subject: Engine failures between 1700 and 2200 (diesel) Quote
For understanding:
With original VAG pump connectors including seals against moisture, or self-made connector solutions?
It's essentially just a $0.10 adjustment, but I was too hesitant to do it myself back then, so I bought it expensively on eBay. It has the original VW connectors and all the necessary components like the gasket.
I'm now wondering if it might be the box itself (due to moisture, etc.).
Michael
Translated on 18-07-2026, 9:38.
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
This topic is locked, you cannot edit or reply. A4 TDI: Stuttering at 1700-2200 RPM (Fixed) Diesel Engine Technology
No new posts Jerkiness at 1700-1900 RPM Diesel Engine Technology
No new posts Passat 3BG AVF: No Power Until 2200 RPM Diesel Engine Technology
No new posts CAAC shuddering between 1700 and 2000 RPM, only above 65%... Diesel Engine Technology
