Does the rear bumper of a Volkswagen Golf IV Sport Edition rattle?
Post11-10-2002, 21:40    Subject: Does the rear bumper of a Volkswagen Golf IV Sport Edition rattle? Quote
First of all, hello to this technically very knowledgeable forum!
What I've seen in the error database surpasses anything I've encountered before! It's also interesting to read about the notes regarding persistent customer complaints, etc.
Regarding my issue:
Since the beginning, I've had a rattling noise coming from the rear right side of my new Golf IV TDI Sport Edition 3-door (96 kW) manufactured in July 2002. The workshop supposedly already replaced the upper damper bearings, and they also adjusted the tailgate and the backrest latch buffers.
"It still rattles with smaller cross-joints etc., but not with larger bumps. It sounds like a loose, heavy metal plate in the spare tire well. A rental car with a 1.4L engine and standard suspension also had this issue, but it was very quiet."
The onboard tools and warning triangle had already been temporarily removed for testing purposes.
What else can I do? This is driving me crazy!
Translated on 17-07-2026, 23:39.
Michael II
Post12-10-2002, 15:35    Subject: Does the rear bumper of a Volkswagen Golf IV Sport Edition rattle? Quote
This reminds me of something.
Sounds from door locks.
Cause:
Due to load transfer movements, some vehicles may experience...
The creaking of the door locks is coming.
Procedure:
Spare part.
Only the index has changed in the new clamping devices.
No. 3B0 837 033 (from index E, G, Q changes to K, and from index D, F, P changes to...).
will be J).
In addition, the following needs to be done:
1. With the door open, clean the locking surfaces that are located in the...
Contact with the locking bar on the body frame is possible.
2. The contact surfaces of the locking bar on the body frame are...
also needs to be cleaned as well.
3. The castle grounds should be sprayed with the product.
The amount is determined by the maximum spraying time of one second.
given.
4. When carrying out the measure, it is essential to pay attention to the door panels.
to protect the surfaces before spraying - risk of permanent damage.
Contaminants.
5. After spraying, the doors remain open for a few minutes.
The spray with the number D 007 000 A2 should be used.
Noises from the door panels.
Cause:
When the armrest is loaded or during driving on uneven surfaces...
Road noise may originate from the area of the door trim.
coming because the door panel is making contact with the inner door frame.
and rubs.
Procedure:
The door panel should have a uniform gap all around.
Inner door panel present. The clearance check can be...
mittels Papier, Visitenkarte oder ähnlichen erfolgen. This should be:
slide easily between the door panel and the inner door skin.
Please provide the text you would like me to translate from German to English. I will then give you only the translation, without any explanations.
A tool moistened with a drop of lubricant (e.g., a business card or piece of paper).
streifen oder Pinsel) durch die Engstelle zu führen. This sliding...
The coating ensures that the components slide smoothly against each other permanently.
to avoid noise.
Release agent: No. G 052 172 A1 or G 052 172 A2.
Tschüss
Michael II
Translated on 17-07-2026, 23:44.
Post12-10-2002, 17:00    Subject: Does the rear bumper of a Volkswagen Golf IV Sport Edition rattle? Quote
Hello Michael II,
The vehicle is only 3 months old; shouldn't it have the latest locking mechanisms installed?! The noise doesn't occur during changes in load, but only when driving over transverse joints in the road surface.
The door panel on the passenger side had been making noises before, but the workshop was able to fix that successfully. However, the rattling sound coming from the rear of the car remained unchanged.
Could the problem also be related to the fuel tank (e.g., the lift pump, float valve, etc.)?
Or the gas springs of the tailgate? Is there any known issue with those?
Thank you!
Translated on 17-07-2026, 23:49.
No new posts Doku 4-cylinder. TDI Clattering/Rumbling, Power Loss Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L MJ 1999: Rattling/Humming Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Acoustic Noise Analysis: Identifying and Locating Sources... General Tips
No new posts Knocking sound from the engine area when releasing the ac... Diesel Engine Technology
No new posts Annoying rattling noise coming from the radio area / cent... Transmission, Chassis, Body & Interior
No new posts REMUS Sound Edition 2002 with 90 PS TDI??? Diesel Engine Technology
No new posts TDI Sport: Upgrade Your Speedometer Transmission, Chassis, Body & Interior
