Replace Airbag Control Unit: Guide & How-To
jannik
Post06-12-2005, 19:01    Subject: Replace Airbag Control Unit: Guide & How-To Quote
Hello.
I want to replace the airbag control unit in my VW Passat TDI 3B5, manufactured in 1999.
I have Vagcom. The control unit number is IJ 909 607 A.
What do I need to be aware of when replacing this part?
Sure, here's the translation:
"Thank you in advance."
Translated on 24-07-2026, 0:42.
Ross-Tech-Support
Post06-12-2005, 19:51    Subject: Replace Airbag Control Unit: Guide & How-To Quote
Besides the fact that the part number you provided is incorrect, there's not much else to worry about. Part number 1J0-909-607-A has not been superseded, and there isn't an index number to be aware of. Therefore, the control unit should currently be coded with "00065," and the new one should also be coded identically. If you try to use a different coding, it will likely not be accepted.
WARNING: According to current laws, work on airbag systems may only be performed by trained professionals! Therefore, the manufacturer's guidelines are the only ones that must be followed.
Translated on 24-07-2026, 0:44.
bloesch
Post06-12-2005, 21:09    Subject: Replace Airbag Control Unit: Guide & How-To Quote
Where do you get the airbag control unit from? As far as I know, it's not normally available for purchase by the general public, or am I mistaken?
jannik
Post06-12-2005, 22:12    Subject: Replace Airbag Control Unit: Guide & How-To Quote
Okay, so the control unit number is correct; I read it out using VAGCOM.
1J0 909 607 A.
The new control unit has the same number.
Purchased from Volkswagen.
Translated on 24-07-2026, 0:45.
jannik
Post06-12-2005, 22:14    Subject: Replace Airbag Control Unit: Guide & How-To Quote
And how do I program the control unit using VAGCOM?
Thank you very much again.
Translated on 24-07-2026, 0:46.
bloesch
Post07-12-2005, 0:30    Subject: Replace Airbag Control Unit: Guide & How-To Quote
Purchased from VW.
Hmm, I guess I was mistaken then... I thought that the control units for airbags were only sold to workshops.
The coding is provided by the original VAG diagnostic tool based on factors such as existing airbags (front, side, head, etc.) and other components.
I don't know that one off the top of my head... but I'm sure someone knows it.
Ross-Tech-Support
Post07-12-2005, 2:00    Subject: Replace Airbag Control Unit: Guide & How-To Quote
Schraubi-Schlumpf wrote:
Where do you get the airbag control unit from? Isn't it normally not available for purchase by 일반 소비자 (ordinary consumers)? Or am I mistaken?
"At VW/Audi, they don't really stick to the guidelines as strictly."
jannik wrote:
So, the number of the control unit is correct; I read it out using VAGCOM: 1J0 909 607 A.
Above, you wrote: IJ 909 607 A.
jannik wrote:
The new control unit has the same number as the old one.
I told you so.
jannik wrote:
And how do I program the control unit with VAGCOM?
As I mentioned above, it must use the same encoding as the old one; otherwise, it won't be accepted.
The original VAG tester provides this coding based on components such as existing airbags (front, side, head, etc.) and other factors.
Yes and no, the coding for this control unit is determined by the parameterization, which is represented by the index, but I already mentioned that in my first post.
Translated on 24-07-2026, 0:48.
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Doku A3 8L, Fehler 65535 im Airbag STG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag Control Unit: Coding Only? On-Board Diagnostics (OBD)
No new posts Airbag-Sitz gegen Recaro tauschen Transmission, Chassis, Body & Interior
No new posts Airbag Control Unit VW Golf 3 On-Board Diagnostics (OBD)
No new posts SRS Airbag Control Unit E220D - W210 On-Board Diagnostics (OBD)
