Daytime Running Lights VAG-COM Installation
Troubleshooter
Post13-12-2005, 11:31    Subject: Daytime Running Lights VAG-COM Installation Quote
Hey guys,
I once heard that with newer models in the VAG lineup, it's possible to activate the daytime running lights that are now required in Austria by changing the country code.
I recently used my VAG-COM (Beta 510-0 USB) to connect to a 2005 Alhambra, but I'm not really getting anywhere. To be honest, I only use VAG-COM to clear error codes, so I don't really know much about the individual coding functions.
Matthias.
Translated on 21-10-2026, 6:02.
Post13-12-2005, 11:45    Subject: Daytime Running Lights VAG-COM Installation Quote
Hi Matthias,
If it's possible, it should be done through the vehicle's body control module (address 09). However, I suspect that your Alhambra doesn't have the corresponding coding option available.
If so, possibly via a "long code" like with the Golf 5.
http://www.ross-tech.com/vag-com/tour/recode_screen.html
Translated on 21-10-2026, 6:03.
Troubleshooter
Post13-12-2005, 12:23    Subject: Daytime Running Lights VAG-COM Installation Quote
I only found things like the horn, rear lock, and similar items under category 09.
Have you ever done that with long coding before?
'Best regards,'
Matthias.
Translated on 21-10-2026, 6:04.
Post13-12-2005, 12:53    Subject: Daytime Running Lights VAG-COM Installation Quote
Yes, could you please tell me the VAG part number of your vehicle's body control module?
Ross-Tech-Support
Post13-12-2005, 14:01    Subject: Daytime Running Lights VAG-COM Installation Quote
The Alhambra has a body control module, but icon_exclaim.gif regardless of the part number, this does not guarantee that the TFL (Traffic Flow Lighting) can be activated via diagnostics. } In short, it is not possible to activate it via diagnostics.
A lengthy coding process (similar to that required for a Golf 5) requires a control unit that a) communicates via KWP-2000 and b) actually supports this function (neither of which the SGA has). The suggestion here is somewhat pointless, especially since Audi manages to do it without lengthy coding (see A4, A6, Aicon_cool.gif. The problem here is simply that the control units in the SGA do not support this function.
You can also order a "retrofit kit" for TFL from your dealer, or have it installed directly (which should cost around 40 EUR, including installation).
*edit*
TFL can be reprogrammed via diagnostics on the following models:
Audi A3 (8P), Audi A4 (8E), Audi A6 (4F), Audi A8 (4E), Audi Q7 (4L), Seat Altea (5P), Seat Leon (1P), Seat Toledo (5P), Skoda Octavia (1Z), VW Caddy (2K), VW Eos (1F), VW Golf (1K/5M), VW Passat (3C), VW Phaeton (3D), VW Touran (1T), VW Touareg (7L)
Translated on 21-10-2026, 6:06.
Troubleshooter
Post13-12-2005, 15:08    Subject: Daytime Running Lights VAG-COM Installation Quote
Greetings, Rainer
The Alhambra is back in the shop. But later today, I'll be giving the Altea a thorough cleaning.
Sure, no problem.
Translated on 21-10-2026, 6:08.
Ross-Tech-Support
Post13-12-2005, 15:11    Subject: Daytime Running Lights VAG-COM Installation Quote
Troubleshooter wrote:
I'll be giving Chefs wife's Altea a thorough inspection later today.
For the Altea (5P), set the corresponding bit in the long encoding as follows:
Code:
STG 09 (Bordnetz) auswählen
STG Lange Codierung -> Funktion 07
Byte 00 Bit 3 - Tagfahrlicht (Skandinavien) aktiv
Translated on 21-10-2026, 6:09.
Troubleshooter
Post21-12-2005, 18:07    Subject: Daytime Running Lights VAG-COM Installation Quote
'For those who might not understand.'
The original encoding is:
00880F2700041000001E00000000000000
What needs to be changed?
Certainly, I'd be happy to help. Please provide the text you would like me to translate from German to English.
Matthias.
Post21-12-2005, 18:32    Subject: Daytime Running Lights VAG-COM Installation Quote
Hi.
Byte 00 is 00 in your system.
Bit...
0 = 1
1 = 2
2 = 4
3 = 8
You need to change the first (okay, the "zero-th") byte from 00 to 08 in your code, and leave the rest unchanged.
Download the latest VAG-COM Beta version from the customer area, as it includes a tool for modifying the long coding.
Translated on 21-10-2026, 6:11.
Troubleshooter
Post21-12-2005, 18:38    Subject: Daytime Running Lights VAG-COM Installation Quote
I already had that, and now I've also figured it out icon_smile.gif.
If I were to tinker around with a few vehicles, that would almost be worth a technical article for Austrian users icon_smile.gif.
'Best regards,'
Matthias.
Translated on 21-10-2026, 6:12.
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Self-activating" daytime running lights (6N, 1M, 1U, 1J) General Tips
No new posts Dim Daytime Running Lights: How & Why Transmission, Chassis, Body & Interior
No new posts Daytime Running Lights on Fog Lights 3C On-Board Diagnostics (OBD)
No new posts Program Daytime Running Lights? On-Board Diagnostics (OBD)
No new posts Daytime running lights - 3BG, year 2004 On-Board Diagnostics (OBD)
