Remote Control Not Working - Golf 4 Fix
rsch
Post23-01-2006, 16:21    Subject: Remote Control Not Working - Golf 4 Fix Quote
Hello, my remote control for my Golf 4, manufactured in February 2002, is no longer working. The diagnostic tool shows error code 01336, "Concerned data bus, comfort, 49-10, communication interrupted." Can anyone help me?
Translated on 08-09-2026, 5:49.
vagtuning
Post23-01-2006, 17:35    Subject: Remote Control Not Working - Golf 4 Fix Quote
A CAN bus typically operates using two twisted-pair wires, designated as CAN-High and CAN-Low.
I would like to take a look at measurement data block 012 in the comfort system (address 46).
Possibly there's something stuck inside, but let's not assume that for now!
Since the error is sporadic, it should be possible to delete it.
If it doesn't register again, then I would start looking at the FFB unit itself (battery).
In measurement block 9, you can see the currently received key value, or 'no signal' if no key is being pressed. If it's not responding at all, it's likely a problem with the force feedback (FFB) system itself.
'Would you like another one?'
Translated on 08-09-2026, 5:50.
rsch
Post24-01-2006, 13:24    Subject: Remote Control Golf 4 Not Working? Quote
Hello! Thank you very much for your reply. Unfortunately, I don't understand what "STG inne fritten" and "FFB" refer to. I deleted the error message, but it reappears immediately. The remote control also doesn't work with the second key. The Golf has had some other issues as well, and I think they are all related. The power windows sometimes don't work, the hazard lights flicker on briefly, the alarm light is on, and the horn beeps briefly. I then removed the door panel and sprayed the connectors with contact cleaner. After that, everything worked again except for the remote control. Best regards, rsch.
Translated on 08-09-2026, 5:52.
hb2000
Post24-01-2006, 15:03    Subject: Remote Control Not Working - Golf 4 Fix Quote
Hello.
Hopefully, your car's control unit isn't submerged in water. You can find the control unit under the carpet in front of the driver's seat. Check there to see if everything is still dry, or if you've experienced any water ingress. If you find any moisture, expose the black box under the carpet and take the control unit to a warm place to dry it thoroughly.
hb2000
Translated on 08-09-2026, 5:53.
Ross-Tech-Support
Post24-01-2006, 15:28    Subject: Remote Control Not Working - Golf 4 Fix Quote
hb2000, the comfort control unit is actually supposed to be located next to the steering column in the Golf 4... icon_redface.gif
No new posts VW Passat: ESP Light On - What to Do? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts Glow Plug Not Turning Off? Engine Won't Start. Diesel Engine Technology
No new posts PLC fails to enter emergency mode On-Board Diagnostics (OBD)
