Torque Specs: Pulley & Seal for 1Z Engine
haehnlein
Post26-10-2002, 16:10    Subject: Torque Specs: Pulley & Seal for 1Z Engine Quote
Hi!
"Since the 'So wird's gemacht' manual is no longer what it used to be for the Passat, I would like to know the tightening torque for the pulley on the 1Z model, manufactured in 03.95. The manual states 25 Nm, but various online installation guides mention things like 10 Nm + 180° or 20 Nm + 180° (which is probably incorrect)."
For the Zykod fastener, use a torque of 40 Nm plus 60 Nm, followed by two passes at 90° each (which, in my opinion, is better than a single 180° pass), without any further tightening.
Thank you in advance.
Best regards, Christian.
Translated on 17-10-2026, 9:32.
No new posts Pulley Service: Audi A4 66/81 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo: Brake Caliper Bolt Torque Specs Transmission, Chassis, Body & Interior
No new posts Loosen pulley/vibration damper? Diesel Engine Technology
No new posts GTI TDI Timing Belt Pulley Issue: Broken on KW? Diesel Engine Technology
No new posts Cylinder Head Bolt Torque Specs 1Z Diesel Engine Technology
