AFN Conversion: Register the change.
cksIT
Post01-02-2006, 14:06    Subject: AFN Conversion: Register the change. Quote
I'm currently in the process of rebuilding my engine. I once read that VW has approvals for such modifications. Since I also want to increase the engine's power, I want to get it registered. It should be obvious to everyone that a car with such a modification won't have 90 horsepower.
Has anyone ever done this before? I couldn't find anything about it in the search results.
Translated on 10-09-2026, 11:44.
Post01-02-2006, 14:21    Subject: AFN Conversion: Register the change. Quote
The conversion from 1Z to AFN should be relatively straightforward, as the resulting configuration was originally built that way (for example, the AFN doesn't have larger brakes).
If you, as a hobbyist, are still tinkering with the engine (AFN) to extract 150 horsepower (which is achievable with just a different gearbox, without any other modifications), you obviously won't be able to get that registered.
Translated on 10-09-2026, 11:45.
cksIT
Post01-02-2006, 20:41    Subject: AFN Conversion: Register the change. Quote
I understand that already. My concern was just about registering the AFN engine. That way, the difference in performance is smaller, and I have fewer problems justifying the car's performance.
Has anyone already had their engine registered?
Translated on 10-09-2026, 11:46.
donalexo
Post01-02-2006, 20:53    Subject: AFN Conversion: Register the change. Quote
Hi cksIT!
I had a similar modification approved for my A3. The base engine in my A3 was an AGR with 90 horsepower and a wastegate turbocharger. I converted it to an AHF with 110 horsepower and a VTG turbocharger (see my profile for details), and everything was approved.
The effort involved should not be underestimated. Find a reliable mechanic you trust, because without documentation and confirmation from a VAG workshop regarding the proper modifications, the TÜV (German technical inspection authority) will not approve the changes.
It is also very important in this context to consider the gear ratios in each gear. You must prove (with a stamp from VAG) that the gear ratio, up to the wheel, does not deviate by more than 8% from that of an AFN Golf in any gear. This means that even the tire sizes are included in the calculation (if they are different).
It might also be very difficult without a copy of the vehicle registration document for an AFN Golf and the service data sticker, because this information cannot be obtained from the dealer (AKTE).
I significantly underestimated the administrative burden involved. Before you take any action, first find a competent contact person at the TÜV (German technical inspection authority) and, in a preliminary discussion, clarify what documentation they require.
Jumping into the cold water unprepared is sure to go wrong.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 10-09-2026, 11:48.
mullemaus
Post01-02-2006, 21:47    Subject: AFN Conversion: Register the change. Quote
Within our circle of acquaintances, someone had a 'Pumpe-Düse' engine upgraded from 90 horsepower to 115 horsepower.
Dekra wanted: A declaration of conformity from VW, which specifies what needs to be changed. This includes the brakes, exhaust (due to the catalytic converter and potentially a better emissions test result), transmission, etc. In addition, a copy of the donor vehicle is required. All of this cost €122 and took less than an hour. icon_wink.gif
Translated on 10-09-2026, 11:50.
cksIT
Post02-02-2006, 8:51    Subject: AFN Conversion: Register the change. Quote
I am specifically looking for this declaration of non-objection.
Where can I get them?
I would never register that part if I didn't have this document, for the exact same reason why donalexo had so much trouble...
Thank you in advance for the answers.
Translated on 10-09-2026, 11:51.
mullemaus
Post02-02-2006, 22:36    Subject: AFN Conversion: Register the change. Quote
We requested this information through an inquiry to the parent company (in WOB) and by asking for a copy of the vehicle registration. icon_wink.gif It will then be sent by mail to your home address, along with all the necessary documents and conditions.
cksIT
Post02-02-2006, 22:59    Subject: AFN Conversion: Register the change. Quote
Does it cost anything? And should I call the main office directly, so they don't look at me like I'm from another planet...
Translated on 10-09-2026, 11:52.
mullemaus
Post03-02-2006, 1:46    Subject: AFN Conversion: Register the change. Quote
Your local VAG dealer will do that for you. It shouldn't cost anything. At least, it shouldn't. ;D
schimme
Karma: +1 / -1   Thank you, like it!
Post05-02-2006, 14:14    Subject: AFN Conversion: Register the change. Quote
Ideally, the friendly staff can print it out for you right there and then. I was there about a year ago to get the required documents and the "no objection" paperwork for a T4, specifically for increasing the gross vehicle weight to over 2.8 tons, and the nice man printed it out for me immediately.
Translated on 10-09-2026, 11:53.
cksIT
Post06-02-2006, 9:10    Subject: AFN Conversion: Register the change. Quote
I'll just ask and see what happens.
Thank you.
No new posts AAZ Engine: Get it registered for your VW T3 Diesel Engine Technology
This topic is locked, you cannot edit or reply. Service Intervals: Everything You Need to Know Diesel Engine Technology
No new posts Register Jubi BBS Wheels 16" with 195/40 Tires Transmission, Chassis, Body & Interior
No new posts AKE to EU3 Conversion for A6 Diesel Engine Technology
