Error codes 17606 and 17607? Help needed
Reno
2002 Volkswagen Passat
Post01-01-2009, 12:01    Subject: Error codes 17606 and 17607? Help needed Quote
Hello everyone.
First of all, I would like to congratulate everyone who contributes to making this forum so great and very helpful. icon_exclaim.gif I wish everyone a happy new year!!!
As it can be seen... I am a newcomer icon_cry.gif.
Okay, let's start with a brief introduction, and then we'll get straight to the actual problem.
My name is Reno, I'm almost 53 years young, and I've had my own workshop for ** years, where I mainly work on Harleys and Corvettes. For about a year now, I've also been working on more vehicles from the VW-Audi group. We have four of them in the family. Of course, I'm also a customer of Rainer Kaufmann. But enough about that, let's get to the topic. Of course, I'm still far from being an expert with the VCDS software, which leads me to the following question:
It's a vehicle belonging to a friend: Passat W8, year 2002, with a Tiptronic transmission.
I can't find the following codes on Ross-Tech WIFI, and my search here hasn't yielded any results either.
17606 - Bank 1, Sensor 2; Heating circuit: electrical fault.
P1198 - 35-10 - - - Intermittent.
17607 - Bank2-Sonde2; Heating circuit: electrical fault.
P1199 - 35-10 - - - Intermittent.
My acquaintance is also sending me the following information:
In my case, the problem only started after I replaced the oxygen sensors, and it reappears in the error memory approximately every 500 kilometers. Sometimes it shows as "fuel economy," and sometimes as "intermittent."
"The first workshop said they would 'regenerate' the sensors (laughter prohibited - *giggles*), but of course, that didn't do anything, and no one could tell me how they would even do that!"
The second workshop, during a re-engine overhaul, measured the sensors and wiring harnesses and supposedly found nothing.
The error will happen again.
"Workshop 1 always wants to replace the control unit – it's frustrating to be at a disadvantage when dealing with them!"
Okay, if you find a solution, I'm interested! Especially because it's not the probe signal itself, but the probe heater that's the issue!!!
"QUOTE-END"
I would be very grateful if someone could provide me with some information on this, as I am really in a difficult situation right now.
Reno.
[b:cf845bf58c]Wer aufhört besser zu werden, hat aufgehört gut zu sein!!![/b:cf845bf58c]
Reno
Post04-01-2009, 11:46    Subject: Error codes 17606 and 17607? Help needed Quote
Can anyone really help me icon_redface.gif icon_cry.gif?
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post04-01-2009, 15:59    Subject: Re: Error codes 17606 and 17607???? Help needed Quote
Reno wrote:
Hello everyone.
The second workshop, during a re-engine overhaul, measured the sensors and wiring harnesses and supposedly found nothing wrong.
QUOTE END
Best regards.
Reno
randomly; out of the blue; without any prior knowledge.
Hello Reno, could it be that the probes are universal types that may have a different heating element, and that's why they are "causing issues" for the system? Can it be compared to the old days?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Post04-01-2009, 18:27    Subject: Error codes 17606 and 17607? Help needed Quote
If things go badly, some intermittent connections may only reappear after weeks or months.
The most comprehensive solution would be to replace the wiring and probes (new parts).
I myself have spent countless hours troubleshooting loose connections on my A3. Looking back, it probably would have been more sensible to replace the wiring directly instead of wasting time trying to fix it.
There is reason to believe, according to Klaus, that both probes are affected.
Reno
Post05-01-2009, 0:27    Subject: Error codes 17606 and 17607? Help needed Quote
Thank you very much for the suggestions. I will take a closer look at this with my acquaintance over the next few days.
Wishing you a happy New Year.
Reno.
Post05-01-2009, 10:27    Subject: Error codes 17606 and 17607? Help needed Quote
Happy New Year
No new posts Fehlercodes Ursachen und Auswirkungen für MKB AMF, ANY Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes 19804/P3348 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI-Timing HILFE seltsame "Fehlermeldung" HILFE On-Board Diagnostics (OBD)
No new posts Golf V TDI Towing: Experiences & Tips Needed! Diesel Engine Technology
No new posts Important: Calibration Pressure & Settling Time: Your Input Needed Diesel Engine Technology
No new posts Important: Ash content and mileage - your input is needed Diesel Engine Technology
