Front Axle Noise: Causes and Solutions
schnuffelvieh
Post08-03-2006, 15:49    Subject: Front Axle Noise: Causes and Solutions Quote
Okay, so it's happened to me too.
After the 'harsh' winter storms and the supposedly very cold winter, I'm now hearing some rather heavenly noises coming from my front axle.
I initially thought it might be a faulty shock absorber or salt on the tire treads, but that's not the case.
Since my 4B is equipped with Xenon headlights, there are axle sensors located on the axles. It's hard to believe, but it's true: these small, dirty things make a noise like a faulty shock absorber.
So, you should probably encounter this issue as well: First, check the wheel speed sensors. A little WD40 might provide a quick, but temporary, fix. However, a new wheel speed sensor will likely need to be installed in the near future.
Basti.
Translated on 14-09-2026, 18:32.
joegolf
Post09-03-2006, 8:57    Subject: Front Axle Noise: Causes and Solutions Quote
I've also experienced that: icon_sad.gif
/viewtopic.php?t=10444&highlight=
Golf 7 GTI
Translated on 14-09-2026, 18:33.
schnuffelvieh
Post09-03-2006, 10:36    Subject: Front Axle Noise: Causes and Solutions Quote
And so far, is it quiet, or is there still occasional trouble?
joegolf
Post09-03-2006, 12:57    Subject: Front Axle Noise: Causes and Solutions Quote
schnuffelvieh wrote:
And so far, is it quiet, or does it occasionally cause trouble again?
So far, everything is quiet, but I'll have to wait until the weather gets drier again. However, I will lubricate the joint during the next tire change.
Golf 7 GTI
Translated on 14-09-2026, 18:34.
schnuffelvieh
Post09-03-2006, 13:01    Subject: Front Axle Noise: Causes and Solutions Quote
And that is just a ball joint, and you can 'easily' take it apart? That would certainly be a good thing icon_lol.gif.
joegolf
Post09-03-2006, 17:29    Subject: Front Axle Noise: Causes and Solutions Quote
And that's just a ball joint, and you can "easily" take it apart? That certainly wouldn't be bad icon_lol.gif
I didn't disassemble it; I just applied silicone (which creeps everywhere) and moved it back and forth.
It's a rubber composite part.
Golf 7 GTI
Translated on 14-09-2026, 18:35.
schnuffelvieh
Post09-03-2006, 20:37    Subject: Front Axle Noise: Causes and Solutions Quote
Okay, then I'll get started on that icon_smile.gif because the weekend is almost here icon_lol.gif.
No new posts Front Wheel Bearing Noise (Golf 4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clunking Front Axle - Documentation 2D (until 03/2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Phaeton Noise: Front Axle 3D2 Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Pedal Noise: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Squeaking Springs After Front Shock Replacement Transmission, Chassis, Body & Interior
No new posts 4-Motion Rear Noise? KW GmbH Fixes It! Transmission, Chassis, Body & Interior
No new posts T4 front axle Upload
