golf3schrauber Blaumann
Joined: 10/15/2003 Posts: 140 Karma: +1 / -0 Location: Erkelenz
18-12-2004, 22:16 Subject: Shock Absorber Boot: Do You Really Need One? |
I just replaced the shock absorbers on the rear axle and noticed that I've been driving with rubber suspension for years.
The shock absorbers are resting on the buffer stops.
The car has been lowered for eight years, and no one has noticed.
But what can we do?
If I cut something off the top of the buffer, the guide on the piston rod will be damaged. If I cut something off the bottom, I will no longer have the protective tube.
Can I operate the shock absorbers without this protective tube?
Completely eliminating buffers is probably not a great solution either.
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 15-09-2026, 17:57.
christians Profi-Schrauber
19-12-2004, 23:15 Subject: Shock Absorber Boot: Do You Really Need One? |
Why change anything if it still works well?
In more modern vehicles, the rubber components are no longer just simple bumpers; they also actively contribute to the suspension system without requiring lowering, creating a progressive spring characteristic and, in particular, taking different load conditions into account.
Or is the car's suspension already far too stiff after 8 years?
Gruß Christian
Translated on 15-09-2026, 17:58.
e_holger Guest
20-12-2004, 16:55 Subject: Shock Absorber Boot: Do You Really Need One? |
Without protection, water and dirt can get onto the shock absorber, which is unlikely to have a positive effect on its lifespan. For example, with H&R coilover suspensions/FW, the warranty is void if the protective cover is not installed! So, it's better to leave it on and continue enjoying the elastomer suspension.
Translated on 15-09-2026, 17:59.
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
20-12-2004, 16:59 Subject: Shock Absorber Boot: Do You Really Need One? |
Does that mean they forgot to remove the transport restraints again?
Translated on 15-09-2026, 18:00.
Profile PM Garage |
