reuselkopp Blaumann
26-05-2006, 6:45 Subject: Zahnriemenwechsel: Find cheap tool manufacturers. |
I'm looking for someone in this forum who can fabricate the special tools needed for the timing belt replacement on an AFN engine at a reasonable cost. Unfortunately, I can't weld myself and I only have basic DIY tools available. The parts are ridiculously expensive as accessories, and as I've read here, they can be easily made yourself.
The following needs to be created:
- Camshaft alignment tool
- Countershaft sprocket (VW 3036)
- Possibly a spanner with a rotating jaw and a pin for the fuel injection pump rotor.
I hope someone finds this...
Greetings.
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 21-10-2026, 4:19.
Hati Guest
26-05-2006, 17:40 Subject: Zahnriemenwechsel: Find cheap tool manufacturers. |
Hmm, I still have one alignment gauge left over.
Send me your offer, and I will review it.
Translated on 21-10-2026, 4:20.
D. Kurz Guest
27-05-2006, 6:59 Subject: Zahnriemenwechsel: Find cheap tool manufacturers. |
Hello!
If you still have the one-piece impeller, then go to a well-stocked hardware store and get an M15 screw, which is very rare, but it will fit perfectly!
Camshaft locking tool... well... usually, a quick, skillful movement with the AW screwdriver will fix it. If necessary, you can also hold the cam in place with a good valve spring compressor pliers. It's best to do it with two people, and then use a combination wrench and a small hammer to loosen the screw. It might all sound a bit rough, but it's worked perfectly for me for years.
'Spline wrench for the tensioner... a bent snap ring pliers will work just as well, any cheap one from the tool rack at Obi, it doesn't require much force.'
Dominique.
Translated on 21-10-2026, 4:21.
reuselkopp Blaumann
28-05-2006, 20:16 Subject: Zahnriemenwechsel: Find cheap tool manufacturers. |
@Hati
I sent you a private message!
@D. Briefly.
That sounds quite simple, actually. However, I still have a few questions. What is an AW-Schrauber? Is the camshaft held in place by the WaPU (a type of bearing) between the cams, or is it the cam itself that is held?
Translated on 21-10-2026, 4:23.
D. Kurz Guest
29-05-2006, 5:55 Subject: Zahnriemenwechsel: Find cheap tool manufacturers. |
Hello Reuselkopp!
AW-Schrauber = Impact wrench...
Make sure there's enough clearance between the cam lobes; that's why it's important to use a good quality valve spring compressor so that no debris is created. Any marks that might appear on the cam lobes would be undesirable.
Dominique.
Translated on 21-10-2026, 4:24.
29-05-2006, 6:31 Subject: Zahnriemenwechsel: Find cheap tool manufacturers. |
@reusel
If you can find a welder, he might be able to quickly weld this together for you.
At least, I built it using recycled iron, and it's holding up - at least for one JX and one AAB camshaft wheel.
[img]/download.php?id=868[/img]
Profile PM Garage |
reuselkopp Blaumann
29-05-2006, 9:06 Subject: Zahnriemenwechsel: Find cheap tool manufacturers. |
@ dieselmartin
Hi, unfortunately, I don't know anyone who can weld. How about you? Would you be willing and have the time to build such a tool for me? Of course, not for free...
Translated on 21-10-2026, 4:25.
29-05-2006, 9:24 Subject: Zahnriemenwechsel: Find cheap tool manufacturers. |
Hi reusel,
Where are you from?
I bought the rolling machine for 8 euros - cheaper than the shipping cost if you order it from somewhere else.
Translated on 21-10-2026, 4:26.
Profile PM Garage |
reuselkopp Blaumann
29-05-2006, 11:09 Subject: Zahnriemenwechsel: Find cheap tool manufacturers. |
I live in Bad Camberg. To create a tensioning roll, I'll probably buy one of those snap ring pliers. Or, they cost around 10€ including shipping at iiibee.
I didn't really want to use a timing belt just to replace the camshaft sprocket. I know my way around cars, but something's bound to go wrong, and then I'll be stuck and won't be able to get the car running again.
rodNeX Guest
06-06-2006, 0:50 Subject: Zahnriemenwechsel: Find cheap tool manufacturers. |
It actually works without special tools, as long as you install the new one exactly the same way as the old one.
Translated on 21-10-2026, 4:27.
