LDA 5mm Fitting for Pressure Hose
MarkusAFN
Post04-02-2003, 21:28    Subject: LDA 5mm Fitting for Pressure Hose Quote
Here's something else about installing an LDA (Linear Drive Actuator).
The VDO gauge has a 5mm quick-connect fitting on the back, while the VW pressure hose has an inner diameter of about 2-3mm. Did you use an adapter for this (is something like that readily available, or do I need to find something myself?)?
Thank you.
Translated on 24-09-2026, 15:10.
DocSnydor
Post05-02-2003, 8:25    Subject: LDA 5mm Fitting for Pressure Hose Quote
I also faced the same problem and solved it forcefully icon_lol.gif. So, I simply stuffed the hose onto it; it's made of rubber on the inside, so it should fit. And then I put the plastic nut on top, so it can't come off anymore...
Translated on 24-09-2026, 15:11.
christians
Post05-02-2003, 13:09    Subject: LDA 5mm Fitting for Pressure Hose Quote
I used parts from the hardware store, specifically from the garden/fountain section (to temporarily connect a pressure gauge). However, I can't guarantee that they will work for all diameters. At the university institute, the adapters were always custom-made.
Gruß Christian
Translated on 24-09-2026, 15:12.
No new posts Hose with a tear Upload
No new posts LDA Connector: Installation & Guide Diesel Engine Technology
No new posts LMM Connector: Types, Wiring & Troubleshooting On-Board Diagnostics (OBD)
No new posts Connection: Charging Pressure Gauge Diesel Engine Technology
