AKE Troubleshooting: Common Errors and Solutions
Dieselmike
Post09-11-2007, 14:35    Subject: AKE Troubleshooting: Common Errors and Solutions Quote
Hello.
I installed an AKE (turbocharger) in my T3. The engine originally came with an automatic transmission, but I'm using a Porsche gearbox. I've fixed the issues related to the crankshaft sensor (it took about 4 months), and the engine runs well. However, I think it's running in limp mode because the acceleration with a maximum boost pressure of 0.7 bar is not satisfactory. It feels like it's pulling like chewing gum. I took it directly to Audi, and they couldn't find anything specific, except that I have error codes stored that they can't clear (fuel injector), which, according to Audi, is not normal.
Question:
Is there anyone here who is an expert and can help me with my car and take a look at it? Of course, not for free.
Which tuner is capable of reprogramming the engine control unit (ECU) and optimizing it for the specific car?
Best regards and thank you.
Mike.
Translated on 22-09-2026, 11:04.
christians
Post11-11-2007, 0:15    Subject: AKE Troubleshooting: Common Errors and Solutions Quote
A faulty injector control valve does not trigger the emergency mode, and the VP44 pump does not necessarily require it.
I'm not really knowledgeable about engine control units (ECUs), but usually, they can be adapted to either manual or automatic transmissions. So, it's not really proper programming. As far as I know, the engine and transmission control units communicate in the A6. If the automatic transmission isn't present and therefore not sending any signals, that could potentially be the reason for the limp-home mode.
Perhaps this question would be better suited for the "Engine Control Units and Diagnostics" forum.
Gruß Christian
Translated on 22-09-2026, 11:05.
Dieselmike
Post16-11-2007, 14:48    Subject: AKE Troubleshooting: Common Errors and Solutions Quote
Thanks for moving it. The issue with the transmission could certainly be related. Try to get a control unit from a similar vehicle. To do this, I need to remove the old one so that Audi can determine a comparable vehicle type.
Translated on 22-09-2026, 11:06.
mullemaus
Post16-11-2007, 23:04    Subject: AKE Troubleshooting: Common Errors and Solutions Quote
You can usually reprogram that from the automatic transmission. If that doesn't work, reflashing it is also sufficient icon_wink.gif. You don't necessarily need a new control unit for that.
Translated on 22-09-2026, 11:07.
Dieselmike
Post19-11-2007, 12:12    Subject: AKE Troubleshooting: Common Errors and Solutions Quote
Which brings us back to the question of who would do something like that (reflashing the device).
Thank you for your help.
Post19-11-2007, 14:17    Subject: AKE Troubleshooting: Common Errors and Solutions Quote
You have a private message.
No new posts Troubleshooting manual air conditioning system, Volkswage... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Troubleshooting Performance Issues Troubleshooting & Guides
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fehlersuche bei A4 B6 (AVB) Diesel Engine Technology
No new posts VTG / N75 Fehlersuche bei 1,2 TDI PD ANY Diesel Engine Technology
No new posts Troubleshooting Climatronic Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Guided troubleshooting with VAG Com? On-Board Diagnostics (OBD)
