Comfort Control Unit: Differences Explained
ard
Post23-07-2006, 17:48    Subject: Comfort Control Unit: Differences Explained Quote
"I have a 1C0 959 799 B control unit in my Golf and I wanted to get a replacement before I make any modifications. What are the actual differences between control units with the same number but different letters?"
So far, I have seen:
1C0 959 799 C
1C0 959 799 G
1C0 959 799 AH
or are they compatible with each other?
Thank you for the helpful response for a beginner regarding VAG electronics.
Translated on 10-09-2026, 7:47.
Ross-Tech-Support
Post23-07-2006, 17:53    Subject: Comfort Control Unit: Differences Explained Quote
Since the actual index/color code is missing, only a general statement can be made, but in short, it is incompatible.
Translated on 10-09-2026, 7:48.
ard
Post23-07-2006, 19:41    Subject: Comfort Control Unit: Differences Explained Quote
Okay, thanks, I was almost certain you'd say that.
But what about the color/index code? So far, I've only been able to read it through OBD, and all I get is the telephone number.
Is the part number alone sufficient to determine the function?
Translated on 10-09-2026, 7:49.
Ross-Tech-Support
Post23-07-2006, 20:00    Subject: Comfort Control Unit: Differences Explained Quote
ard wrote:
But what about the color/index code? So far, I've only been able to read it via OBD, and that only shows the telephone number.
This section specifies the configuration options, such as the number of doors (2 or 4), body style (hatchback or station wagon, etc.).
ard wrote:
Just look at the component designation.
Does the part number alone
not suffice to determine the function?
The "standard" part number is only a rough approximation; if you need specific details, you'll need the complete part number.
Translated on 10-09-2026, 7:50.
No new posts Comfort control unit differences? A6 4B Transmission, Chassis, Body & Interior
No new posts Problems with the comfort control unit On-Board Diagnostics (OBD)
No new posts PIN Assignment Comfort Control Unit On-Board Diagnostics (OBD)
No new posts IBIZA 6L Comfort Control Unit On-Board Diagnostics (OBD)
