VTG Closed: How to Disable/Remove the Alert.
reuselkopp
Post13-10-2006, 10:31    Subject: VTG Closed: How to Disable/Remove the Alert. Quote
Hey everyone,
I'm on the trail of my turbo lag issue. I recently started a thread here about it, and was close to just removing the turbo altogether. After reviewing Ulf's article on adjusting the VTG (Variable Turbine Geometry) mechanism, I had the idea that my "VTG open" stop might be misadjusted. And it seems like that's exactly what's happening. After feeling around with my fingers (it's incredibly cramped in a Golf 3), I immediately noticed that the screw is completely loose and can be easily turned with just a finger. That shouldn't be the case.
How can I best access it without removing the charger? Are there any standard measurements for how far the screw should protrude from the bottom? How could this even happen, despite the locking screw and the paint?
Greetings.
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 07-08-2026, 14:05.
reuselkopp
Post16-10-2006, 7:33    Subject: VTG Closed: How to Disable/Remove the Alert. Quote
Is there anyone who has any experience with this?
Greetings.
Reuselkopp.
Translated on 07-08-2026, 14:07.
Herr Antje
Post16-10-2006, 7:55    Subject: VTG Closed: How to Disable/Remove the Alert. Quote
So, no one will probably ever know how this screw came loose. Maybe there wasn't enough paint, it got too hot and the paint softened, someone might have tampered with it before, or (most likely) due to vibrations.
Due to the cancellation. You might have to try something else, or perhaps the information in this post will help you.
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 07-08-2026, 14:08.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MSW Error in ALH: Log Values OK? Diesel Engine Technology
No new posts AGR Valve Closed: When & Why? Diesel Engine Technology
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts PD Ignition Timing: How to Adjust It? On-Board Diagnostics (OBD)
