Hello, I've been driving a Passat 3C sedan with a 125 kW TDI engine since September, and unfortunately, there was no factory option available for an off-road suspension or similar.
Common "lift kits" like those from Seikel or WEITEC do not offer a mechanical lift, among other reasons because my 3C has rear suspension with automatic leveling.
SEIKEL suggested in an email that I contact Volkswagen to inquire whether it's possible to achieve a "lift" or increase in ride height through the automatic leveling system, and that this "lifting" is likely controlled electronically.
Therefore, I think I will also get a corresponding answer here in the forum (hopefully
Is it possible to use VAG-COM and the corresponding control units to raise the vehicle by approximately xxx cm? I know it would only affect the rear, but there are (mechanical) lift kits available for the front.
Thank you for your answers!
