Golf 4 / New Beetle
Inspection of the visual connection on the gearbox control panel.
Affected vehicle identification numbers (VINs):
WVW ZZZ 1JZ WB 000 001 to WVW ZZZ 1JZ WB 999 999.
WVW ZZZ 1JZ XB 000 001 to WVW ZZZ 1JZ XB 010 455.
WVW ZZZ 1JZ WD 000 001 to WVW ZZZ 1JZ WD 999 999.
WVW ZZZ 1JZ XD 000 001 to WVW ZZZ 1JZ XD 009 980.
WVW ZZZ 1JZ WP 000 001 to WVW ZZZ 1JZ WP 999 999.
WVW ZZZ 1JZ XP 000 001 to WVW ZZZ 1JZ XP 061 100.
WVW ZZZ 1JZ WW 000 001 to WVW ZZZ 1JZ WW 999 999.
WVW ZZZ 1JZ XW 000 001 to WVW ZZZ 1JZ XW 050 834.
Cause:
In vehicles within the affected vehicle identification number (VIN) ranges, there is a possibility that screws securing the transmission to its housing may loosen during operation. This could lead to the stripping of the internal threads in the transmission housing and, potentially, to the detachment of the transmission from its mount.
Procedure:
Replace the existing transmission console screws.
Important:
No active customer notification is being sent.
Tschüss
Michael II
Translated on 27-07-2026, 8:01.
