Corrosion protection needed
smith2
Post12-09-2006, 14:55    Subject: Corrosion protection needed Quote
I want to install a strut tower brace on the front axle of my vehicle. This brace will be bolted to the strut towers with three bolts each. To prevent the body from rusting around the drilled holes, I need to protect it adequately against corrosion. Is standard rust protection spray from a hardware store sufficient, or do I need something special? I will definitely apply some undercoating underneath.
Thank you for your tips.
'cu' translates to 'see you' or 'goodbye' in Spanish. It can also be used as a greeting, similar to 'hi' or 'hello.'
smith2
Translated on 20-07-2026, 7:50.
bastion
Karma: +6 / -1   Thank you, like it!
Post12-09-2006, 15:03    Subject: Corrosion protection needed Quote
My friend sprayed some bitumen sealant between the dome strut and the body panel in addition to using the adhesive film, and then attached the strut while the sealant was still liquid. He also did this from both sides.
So far, nothing has shown any signs of rust (2 years).
A4 Avant 08/01 AWX 05/08-
Translated on 20-07-2026, 7:51.
BM
Avatar-BM
Post12-09-2006, 16:19    Subject: Corrosion protection needed Quote
A friend of mine, in addition to the film, also sprayed bitumen spray between the dome strut and the bodywork, and then mounted the strut there while it was still liquid. He did this from both sides.
You can almost do without the dome strut in that case.
If you want a stiff connection, which is the whole point of these strut bars to reduce twisting in the dome area, you also need adequate clamping force between the shock absorber dome and the strut bar.
Therefore, from a purely static perspective (excluding the rust protection on the holes – zinc dust paint), there is nothing between the parts that should be present and that would facilitate their interaction or function together.
I would ensure that the areas where the strut and screws are mounted are free of any interfering substances (e.g., plastic film, bitumen, underbody sealant) both before and after installation.
I would seal the entire thing with cavity wax and reapply it periodically.
3B5 AJM
Translated on 20-07-2026, 7:53.
smith2
Post13-09-2006, 13:18    Subject: Corrosion protection needed Quote
Thank you for the tip 'BM.' I will do it that way.
I'm going to go get the underbody protection applied later today for further treatment.
I have zinc spray available.
smith2
Translated on 20-07-2026, 7:54.
No new posts Erwin - Looking for a repair manual for VAG vehicles Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Looking for a diagnostic tool? Diesel Engine Technology
No new posts AI Specialists A4 B5 - We're Hiring! On-Board Diagnostics (OBD)
No new posts Fuel Injector 0434250071 - Buy Now! Diesel Engine Technology
No new posts ARL photos wanted Diesel Engine Technology
