External temperature sensor and tank level sensor disconnected
alex106
Post01-10-2006, 13:39    Subject: External temperature sensor and tank level sensor disconnected Quote
I hope someone can help me.
My fuel gauge has been malfunctioning since today. I just read out the error codes.
Fuel sensor disconnected.
Ambient temperature sensor disconnected.
I'm not entirely comfortable with the fact that these two errors are occurring simultaneously. Could it be a problem with the instrument cluster?
Where is the outside temperature sensor located in the Seat Ibiza 6L?
My car:
Seat Ibiza 6L, year of manufacture 2002.
96 kW
1.9 TDI
Post01-10-2006, 13:43    Subject: External temperature sensor and tank level sensor disconnected Quote
I can't say for sure, but early Ibizas had the fuel cap on the outside of the driver's side mirror. Otherwise, check the front bumper, usually on the left side.
If the errors occurred simultaneously, the possibility of a defect in the connectors to the AI system or in the AI system itself cannot be completely ruled out.
Ross-Tech-Support
Post01-10-2006, 13:46    Subject: External temperature sensor and tank level sensor disconnected Quote
Could you please post a complete diagnostic report (car scan)?
sik
Post01-10-2006, 13:51    Subject: External temperature sensor and tank level sensor disconnected Quote
The outside temperature sensor is located on the left-hand side in the direction of travel, next to the fog light... it's simply clipped in place there.
alex106
Post01-10-2006, 13:57    Subject: External temperature sensor and tank level sensor disconnected Quote
Thank you for the answers so far!
I'm going to go watch something now.
Is there any way to get in touch with Tangegeber? Is it possibly located directly under the seat bench?
I hope it's not due to the AI.
No new posts Audi B4 Avant: Antenna Amplifier Cable Broken Transmission, Chassis, Body & Interior
No new posts Remove the fuel sender Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Color for upstream and downstream at the tank sensor? Diesel Engine Technology
No new posts Fuel sensor Passat 3B Syncro/4Motion Transmission, Chassis, Body & Interior
