How to change brake fluid.
leo_b
Avatar-leo_b
Post30-10-2006, 14:12    Subject: How to change brake fluid. Quote
hi,
Inspired by various discussions about brakes and clutches (hydraulic systems), I wondered how brake fluid is actually changed.
With or without the area for the clutch actuation?
I don't think anyone will do that!
Therefore, only very old Asbach brandy is being passed back and forth.
or am I wrong?
best regards, leo
Mein Bussi: Trapo, 7/1999, Kombi L, 8 Sitze, Indianblau, 88PS (65kW) TDI, MKB: AJT, GKB: DUJ, mit kleinem LLK, 340000km
Translated on 19-10-2026, 4:15.
Post30-10-2006, 14:18    Subject: How to change brake fluid. Quote
Okay, I'm doing the clutch brake fluid replacement. It takes about 5 minutes longer.
Otherwise, there are guides and/or user experiences available here.
Remove all tires, attach containers, connect the vacuum pump with the HL vessel, and continue filling until new BF (presumably referring to a fluid) appears, then add VR and HR to the VL (presumably referring to a liquid).
If you want to bleed the clutch (the fluid in the clutch system likely mixes very little with the brake fluid), there are several ways to do it. A simple method is to use the brake pedal and a connection between the brake caliper and the clutch bleed screw to push the fluid through. Alternatively, you can use a vacuum pump. Be careful to keep the fluid level in the reservoir high enough, as the clutch reservoir often has a small compartment at the back.
Translated on 19-10-2026, 4:17.
leo_b
Avatar-leo_b
Post30-10-2006, 14:36    Subject: How to change brake fluid. Quote
hi matthias,
I already understand that it should be done and how to do it.
However, there are some vehicle models where replacing the receiver-dryer is significantly more complicated.
like with my T4.
It will definitely take more than just 5 minutes.
And that's why it's often not done.
best regards, leo
Translated on 19-10-2026, 4:18.
Post30-10-2006, 15:17    Subject: How to change brake fluid. Quote
Okay, generally speaking, many systems are structured in a very similar way.
If you're implying that workshops don't do it... well, read the workshop reports; it's not the only thing that's often overlooked.
I also believe that, in this particular case, adding a small amount of "Fusch" (likely referring to a non-specified substance) might not be the worst thing, as my opinion is that the thermal stress on the clutch master cylinder fluid is likely low, and therefore should rarely, if ever, reach a critical level. I only foresee a minimal dilution of the new brake fluid.
Translated on 19-10-2026, 4:19.
Karma: +594 / -0   Thank you, like it!
Post31-10-2006, 23:15    Subject: How to change brake fluid. Quote
Hi!
I'm more concerned about the risk of rust forming inside the cylinders or a lot of dirt accumulating.
and this can cause them to leak.
But it doesn't seem to be that dramatic.
because the brake fluid in my old T3 has also been in there for at least 15 years.
Sure, no problem.
Translated on 19-10-2026, 4:21.
Post01-11-2006, 15:26    Subject: How to change brake fluid. Quote
Well... if everything is working correctly, nothing will oxidize. And as for dirt? Well, there's no flow except when you're changing something.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Timing Belt Replacement: Cost & Procedure Diesel Engine Technology
No new posts Temperature Sensor Replacement Diesel Engine Technology
No new posts Crankshaft Screw Replacement for AAZ Engine Diesel Engine Technology
No new posts AFN ECU Replacement: Tuning Chip Compatibility? On-Board Diagnostics (OBD)
