Mike² wrote: |
Or do you require any further information?
The MKB wouldn't be bad...
but the search function excludes the thread
https://community.dieselschrauber.org/en/viewtopic.php?t=1793&highlight=17911.
The error code 17911 is also mentioned there.
Error code: 17911.
Load signal from generator terminal DF: implausible signal.
Possible causes:
Generator failure.
Voltage regulator faulty.
Power outage.
Possible effects:
Auxiliary heating not working.
So, if your on-board voltage is incorrect due to a defect (see above), then the other errors are likely secondary issues resulting from that initial problem.
