Uwe Profi-Schrauber
Joined: 04/15/2002 Posts: 1004 Karma: +5 / -0 Location: Westerwald
20-10-2006, 20:38 Subject: Speedometer signal: 6-speed same as 5-speed? |
After upgrading my now quite old A3 with a 6-speed gearbox and 110 horsepower, I've noticed that the speedometer seems to be reading a bit optimistically.
In the lower speed range, I have over 10% over-advance. Due to a lack of sufficient space, I haven't measured it yet at Autobahn speeds.
Unfortunately, I don't have a reference value for my old gearbox. Could it be that the sensor is providing a few more pulses than the old 5-speed gearbox? Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Translated on 29-09-2026, 12:29.
DariusPolo Guest
23-10-2006, 12:33 Subject: Speedometer signal: 6-speed same as 5-speed? |
Hello!
...do you have any pictures of your renovation?
Darius.
Translated on 29-09-2026, 12:30.
Uwe Profi-Schrauber
25-10-2006, 21:57 Subject: Speedometer signal: 6-speed same as 5-speed? |
DariusPolo wrote: |
Yep, you can find them here. Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Translated on 29-09-2026, 12:31.
Uwe Profi-Schrauber
22-11-2006, 15:48 Subject: Speedometer signal: 6-speed same as 5-speed? |
*Bump*, as the question is still unanswered. Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Steffarn Profi-Schrauber
10-12-2006, 15:49 Subject: Speedometer signal: 6-speed same as 5-speed? |
Yes, Signal is the same. Even the connector fit on my A4 when I changed from a 5-speed to a 6-speed transmission. B.Eng (FH) u. KFZ Meister
Profile PM Email Garage |
Uwe Profi-Schrauber
10-12-2006, 18:08 Subject: Speedometer signal: 6-speed same as 5-speed? |
Thank you for the information  . Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
