TDI Engine: Troubleshooting "Quack" Noise
delvos
Post04-11-2002, 9:49    Subject: TDI Engine: Troubleshooting "Quack" Noise Quote
I'm new here and I already have a question.
My new TDI (currently 5,700 km, see signature below) has been making a squeaking noise from the beginning when releasing the clutch. It also makes the noise when quickly releasing the accelerator pedal with a gear engaged. Therefore, it's not related to the clutch.
In the workshop, they are at a loss. As a test, I suggested disconnecting the EGR valve (which I did), but that didn't solve the problem either.
I don't think it's coming from the turbo either, because a new one was installed at a mileage of 2,600 km (due to a complete turbo failure seemingly out of nowhere). icon_confused.gif
Ist das Geräusch normal?? Who has an idea?
Greetings.
Rudi.
Translated on 31-10-2026, 20:33.
delvos
Post04-11-2002, 16:04    Subject: TDI Engine: Troubleshooting "Quack" Noise Quote
Am I the only one with this "problem"?
I can't imagine that.
Has anyone heard of any of this before?
Translated on 31-10-2026, 20:35.
Post04-11-2002, 16:11    Subject: Once Upon a Time: A Nostalgic Story Quote
Hi.
. . . similar entries in the error database.
Take a look around a bit.
I don't know if this applies to the 130 hp version, but it might be helpful.
delvos
Post05-11-2002, 11:50    Subject: TDI Engine: Troubleshooting "Quack" Noise Quote
I've already seen that. However, the noises I'm experiencing occur while driving, not when the car is stationary, as described there.
Despite that, we took the AGR suggestion into account, but it didn't work.
Rudi.
Translated on 31-10-2026, 20:36.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Is an internet connection mandatory when accessing ECUs? On-Board Diagnostics (OBD)
No new posts ESP VP37 Removal: AEL Engine (A6 2.5 TDI) Diesel Engine Technology
No new posts Golf TDI: Stuttering When Coasting to a Stop Diesel Engine Technology
