Audi A6 (AEL), cold start... idle speed fluctuates
mrfree
Post04-01-2007, 11:22    Subject: Audi A6 (AEL), cold start... idle speed fluctuates Quote
When I start my Audi A6 (AEL, 1995) in the morning (cold start), the idle speed fluctuates between 1000 and 750 rpm and it's difficult to start (it seems like only some cylinders are starting well).
I tried with:
* double pre-heating (I'm not sure about this term in eng icon_smile.gif)
* setting timing to a slightly higher value than the standard values (using the vagcom TDI timing tool)
* accelerating a little bit during the start-up
Could this problem be related to G80 Implausible Signal (AEL)??
Thanks, in advance.
Post04-01-2007, 12:49    Subject: Audi A6 (AEL), cold start... idle speed fluctuates Translating...
[Translating...]
Hi Laurento,
are you sure all glow plugs are ok and heat well ?
Is the wiring of them as easy accessible as it is in other TDIs ? The 1Z allows to unplug the wire (in fact it's one metall-rubber piece) very easy by just pulling it off the glow plugs.
If the AEL allows this too, try to remove it and measure the resistance of the plug. It should be at 0.8 Ohms for a cold engine and cold plug.
After 11 years one or more plugs may be dead, which results in cold start problems and occurs not until winter.
mrfree
Post04-01-2007, 12:57    Subject: Audi A6 (AEL), cold start... idle speed fluctuates Translating...
[Translating...]
dieselmartin wrote:
Hi Laurento,
I'll check them tomorrow using a tester and I'll post here the inspection-result icon_wink.gif
mrfree
Post06-01-2007, 15:33    Subject: Audi A6 (AEL), cold start... idle speed fluctuates Translating...
[Translating...]
For 4 plugs the tester reports 0.8 ohm and for the remaining plug 0.7 ohm
May I make some other useful tests?
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Audi A3 1,9tdi glühkerzen lampe blinkt nach start hilfe On-Board Diagnostics (OBD)
No new posts ajm leistungsprobleme ruckeln idle.log Upload
No new posts Schlechter kalt start mit viel Rauch Diesel Engine Technology
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
